Question about Kenmore Elite HE5t Washer
HE5T Model number 110.47081600. f20 code. Checked inlet hose screens and hose. Water if flowing just fine into machine. Keep getting f20. Is there a parts manual so I can go inside the machine with some confidence? Thanks, John
jsrock516
  • 5911 Answers
SOURCE: Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Posted on Jan 06, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a knemore elite
If you have questions, or require additional assistance, please let me know. I hope this helps you.
  • 254 Answers
SOURCE: KENMORE ELITE HE3T CODE F-02
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Posted on Apr 01, 2009
agitateme
  • 88 Answers
SOURCE: i have a kenmore elite HE5t steam front load
I've seen this complaint 5-6 times within the last month. Try this. Remove the top panel by removing the three screws along the back and pushing the panel back and then lifting up. Locate the pressure sensor mounted on the right side of the machine. Check the pressure sensor hose very carefully for splits or cracks caused by chafing on the tub. You really need to look closely, it only takes a tiny pin hole. If damaged, replace hose and make sure the new hose is routed properly, not taped to the tub as some of the new ones have been for some reason.
Posted on Mar 28, 2010
  • 662 Answers
SOURCE: f20 message on washer kenmore elite HE5t
http://www.fixya.com/support/r3608632-f20_error_code
Posted on Jun 04, 2010
I am getting a F20 code. I did the auto diagnostics and It says I am getting no hot water. What should I replace?
NO HOT WATER CHECK THE WATER INLET VALVE AS THE HOT COILS MAY HAVE GONE BAD U CAN CHECK FOR VOLTAGE AND FOR OHMS.. ALSO MORE LIKELY CHECK UR WATER TEMPERATURE SWITCH IT MAY HAVE GONE BAD , USE A METER FOR OHMS CHECK
MAY ALSO WANT TO CHECK UR THERMISTOR ON MODELS WHICH HAVE ONE
Jun 09, 2015 | Kenmore Elite HE5t Washer
My Kenmore Elite HE 5t is showing the F20 code 15-20 seconds into the washing cycle. F20 standing for Water inlet problem. We have cleaned and checked all inlet ports and they are good so what else
Hello Shannon;
My name is Peter. I am a retired field service appliance technician.
Code F20 also stands for pressure switch.
You have a incomplete model number so I am not sure if this is the correct switch.
Substitution: W10514214 - $48.00
This is just inside the top cover, right hand corner.
The diagram is on the following link. Plug in your model number.
Water Filters Lawn Garden Appliance Parts
Dec 11, 2014 | Kenmore Elite HE5t Washer
Got a f20 code on my washer and i have a question
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.FHzIAYn8.dpuf
Oct 05, 2014 | Whirlpool duet Washing Machines
How do I fix F20 code
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.2RAhsfLg.dpuf
Sep 19, 2014 | Whirlpool duet Washing Machines
Getting f20 error code, how to check flow meter operation
Check for stuck socks or something just under the door seal at the bottom of the drum. Check filter for blockage and all outlet pipes. Check the pressure switch hose for any holes as it may have rubbed on the drum and created a small hole in it. Make sure flow meter is level and not at any angle.
Dec 22, 2012 | Whirlpool duet Washing Machines
We keep getting F20 code
F20 No water detected entering machine, bad flow meter leaf switch, clogged water valve inlet screens,pressure switch hose clogged Service manual
Sep 17, 2011 | Kenmore 46462 Front Load Washer
My Kenmore Elite HE5T front loading washer is giving me an F20 (Water inlet problem - no water or insufficient water supply) code. The Drum fills half way up with water in about 5 minutes and then the...
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
  1. There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
  2. Near the pressure switch is a clear plastic hose may be kinked or even have a small hole in it. Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
  3. If this doesn't help then most likely you will need to replace the pressure switch.
Feb 25, 2011 | Kenmore Elite 45986 Front Load Washer
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
F20 inlet water problem, has been fixed twice in 1 week and still has the F20 code. What is the problem.
An F20 code is telling you that the anticpated fill time limit has been exceeded.
This can be caused by
1. Dirty water inlet screens on the water valve. Also possibly the hoses at the wall connection if the unit was installed with additional hose screens.
2. Kinked water supply hoses
3. LOW WATER pressure
4. A weak or open coil of the inlet water valve solenoid.
5. A kinked or restriction of the hose that goes from the water valve to the tub inlet.
6. (VERY RARE) A defective machine control board.
7. Bad faucett washers on the wall connection hose bibb where the rubber faucett washer has deterorated and is blocking or restricting water flow inside the shut off valve on the wall.
8. Debris blocking the diaphram of the water passages inside the inlet water valve (Can not be verified by disassembly due to the construction of the water valve.) You must check flow rate into the tub after verifying all the possibilites above except #6.
These are all real possibilites and each one of them must be checked out. This is not a difficult task and a good many washing machine users should be able to isolate the problem.
If you need machine specific information we will need your make and model number to assist you in the future.
Thanks for choosing FixYa.
Kelly
Sep 02, 2010 | Whirlpool Washing Machines
Recently I have been getting an F20 error message. What does this mean?
Could be a couple things . Clogged inlet screens on the water valve, flow meter gone bad. Pressure tube has sediment in it.
Aug 31, 2010 | Kenmore Elite HE5t Washer
Kenmore Elite HE5t Washer Logo
114 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
