Question about Cameras
I recently bought a 4 gig SanDisk Memory Card (SDHC) and placed it in my Canon PowerShot 300SD camera. It immediately read Memory Card error. What can I do beside returning the card for a full refund?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 04, 2010
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
Hi there! I have a Canon PowerShot SD700 is. I have bought a Sandisk 8 GB. My camera cannot read it. It says: Memory Card Error. What can I do about it? Many thanks for your help
The SD700 works with MMC and SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, which max out at 2GB.
Apr 23, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
May 28, 2010 | Canon PowerShot A540 Digital Camera
Memory card reading " card access error" when printing
is this a SDHC card? if so do u have a SDHC card reader?
Sep 17, 2009 | SanDisk Memory Media
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Feb 23, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
My Powershot 450sd camera is not reading 4GB SDHC
SDHC memory cards are relatively new, and are sadly compatible with only the newest model cameras. For your model camera, recommend a maximum 2GB standard SD card. Fortunately, these days a 2GB card is very inexpensive.
Dec 29, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Cameras Logo
124 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
