The 'touch screen' is not functioning or responding to 'taps'. All other 'push button' functions of phone are working properly. Any suggestions
KIng LeO>> Try re-calibrating the screen, settings>screen> then select "Align Screen". If after you do that, it still doesn't work, try a factory reset.
neldie>> Do a factory reset.
Use a program like PIM Backup (http://www.pocketpcfreewares.com/en/index.php?soft=1806)
Save the backup to your memory card, or back it up and copy it to your computer, the do the Factory Reset. You can then reinstall PIM Backup after the reset and use it to restore most of the stuff on your phone (contacts, call logs, text messages, etc.)
Factory Reset instructions:
•Hold down both soft keys (both above the send and end key's) and use
the stylus to push the reset button in between the volume key and micro
sd slot. Then the screen will turn on and tell you something to the
extent of press "Send" to perform a factory reset. Hit send, and your
good to go.
my screen freezes and i have to take out the battery press the botton to turn it on then wait and nuthing happens and if it does decides to go thru and work for 10 min and then freezes. I will be on a call and just freeze i've only had it for 6 months.
Hi guys a little help i have a t-mobile wing 2 of them and the screen stopped responding. I tried doing the hard reset and what it did was it reverted back to the origional setting however you know how it say touch screen in the begining well I can't click so it wont leave the screen. Does any one know how I cold possibly fix that. I mean I could try to replace the touch screen because the lcd works just fine. Please advice I would really appreciate it
touch screen not working properly
