Question about PfaFF Sewing Machines
My Pfaff tiptronic 6270 presser foot is sticking and now does not put the right pressure on the fabric layers. It does seem to work better after about 30 minutes of use. I purchased the machine new approximately 11 years ago and I have used it very much over the years.
SewTechWayne
  • 186 Answers
SOURCE: Pfaff Tiptronic 6270 just stopped working!
There is a fuse in the the base plate that has blown. It is soldered in and is special fuse you won't find at Radio Shack. Unfortunatly it needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff).
Sorry for the bad news and best of luck.
Posted on Jan 31, 2009
Mimito7
  • 128 Answers
SOURCE: Presser foot adjustment for fine fabric
Hi there, On the top of the machine in the left corner, there should be a knob of sorts. If you turn it to the right, it will releases some of the tension on the fabric. But you don't want to loosen it too much otherwise you won't feed the fabric thru at all.
Posted on Apr 22, 2009
Sewtech1
  • 69 Answers
SOURCE: we jave pfaff 1471 mod - pls explain how you get
it seems like it is dry and needs some sewing machine oil on the shaft.
Posted on Oct 04, 2009
SOURCE: presser foot
to drop the bottom feed open the bobbin area--there may be a switch to the right
Posted on Mar 09, 2010
SOURCE: Have a Pfaff 6270 tiptronic
Hi, well most often when this happens, it is either the Power Supply, or the Controller. However, it also maybe any one of a myriad of "Other" faults, that unfortunately display the same symptoms, ie: lights on, No go, No display..
The very best thing you can do is take it into a Pfaff authorsied servicing center, contact either a local or head office, and ask for a referral to a local service center.
now when there, ask them for a "Quote"as to the repair, and if the "Quote" seems acceptable to you then you have the option of repairing or replacing depending on costings.
Posted on Mar 20, 2011
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
Singer Quantum XL 3400. How do I adjust the presser foot to decrease pressure when quilting several layers?
The owner's manual would most likely have the information. If there is an adjustment is is most likely on the top left of the machine or on the left side of the cover (over the needlebar).
If you are sewing slick fabric that shifts under the presser foot, try using a walking foot or a roller foot.
SINGER Roller Presser Foot Tutorial
Sep 05, 2016 | Singer Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
My Pfaff Tiptronic 6270 does not sew.
Try unplugging the power cord from the machine, let it set for a few minutes and try plugging in again. Sometimes this will reset the machine.
Here are other postings on Fixya that sound similar to your problem:
The memory board went out on my 2000 tiptronic 6270 couple years ago now...
Sep 05, 2015 | Sewing Machines
Bernina 1230 Is there a way to adjust the pressure on the presser foot?
Just checked on U-Tube there are several video's there for problems, otherwise there is a spring at the top of the needle shaft that can be loosened. Good Luck!
Sep 28, 2017 | Sewing Machines
Fabric does not move forward
Either the presser foot does not have enough pressure on it or it is not lowering all the way to the fabric.
Remove the fabric.lower the presser foot.If the presser foot has no or little pressure look for the pressure regulator on top the machine or on the left side and see if you can make it tighter. Not all machines have this.Look to see if there is space between the foot and the teeth when you turn the handwheel. If there is space then the machine needs an adjustment.
sewman7
Apr 27, 2009 | PfaFF Hobby 4260
Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Dec 31, 2008 | PfaFF Tiptronic 2030
Pressure foot problem
hi there not sure if the manual will help but if you go to this link you might find it.
pfaff 7570 manual Google Search
or go to this link might help you to find out why.
pfaff 7570 presser foot wont go down Google Search
Nov 04, 2017 | PfaFF Creative 7570
Sewing Machines Logo
120 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
