Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Ground coffee doser cover brok - Starbucks Saeco Italia Digital Barista Coffee Machine
  • Starbucks Master
  • 1,711 Answers
Why my saeco royal not grinding?
hi,
pls try to describe what are the symptoms.
Grinder might be dead, or the doser switch may say that there's no need for grinding because it feels there is enough ground coffee.
I would clean the grinder completely, clean the doser from all ground coffee and give it a try and let me know.
Hope that helps.
M.
Apr 11, 2016 | Saeco Royal Professional Espresso Machine
Tip
Rancilio Rocky w/ doser: clean sweep of coffee grounds
The Rancilio Rocky coffee grinder is a superb, highly recommended machine, but its doser is pretty useless in the home. First reason: you want to grind coffee instants before you brew or pull your espresso shot; otherwise, the grinds just lose aromatics and flavor. The doser only works for multiple doses, so you're better off just grinding the amount you need each time. If you're buying a Rocky, get the doserless model.
If you have the doser model, like I do, you also find that the vanes which sweep the coffee into your portafilter or cone leave a layer of grounds on the doser floor. If not cleaned out, they turn rancid. There are coffee web sites with fairly complicated instructions on how to modify the vanes to do a clean sweep. Here's the simple way:
Flip up the doser cover, and spin the vanes while pressing your finger lightly on the outer top edge of one vane. The vanes have enough play so the pressure brings one into light contact with the doser floor, sweeping 99% of the grounds into your waiting portafilter.
on Jan 03, 2011 | Rancilio Rocky Espresso Coffee Grinder -...
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
The grinder and the cover don't work i just got this for a gift about 6 months ago i cant believe it does not work. I try fixing but it still doesnt work the entire coffee box and the cover.
  • DIAGNOSIS
  • it can be too tight stringed at burrs
  • some stone or metal part with coffee went between burs
  • IF IT IS AUTOMATIC, it can be one of 2 micro-switches or main relay, in this case you have power but only to middle of way.
SOLUTIONS
  1. Release the burrs, grind one amount coffee with bigger granulation than go back again carefully.
  2. Disassemble the upper burr holder and clean carefully, all coffee and remains put in one plate, inspect with magnet, hand and than put all that in water. (heavy parts fell down fast in water)
  3. Check the switches and relay:
  • Upper micro-switch has an plate and one box where it is( box might be full of coffee or the plate blocked and giving the signal of full doser every time)
  • Lower micro-switch should activate every 6th pull of doser(he is below in mechanism of doser)
  • Relay gets power from micro-switches when they command. even we switch on if the commandsof micro-switch says off than relay will not obey us.
Nov 25, 2010 | Coffee Makers & Espresso Machines
Not fine enough for espresso
solved please donate on my paypal account daniels.sergio@gmail.com to get the answer
Jul 09, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Saeco digital plus not grinding
Sounds like your grinder is clogged and do you hear a clack, clack? That would be the solenoid opening the doser box.
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
No coffee being dispensed
I had a similar problem- you need to re-adjust your grinder setting again. It took me several tries to re-adjust and finally it is back working.
Jun 11, 2008 | Saeco Royal Professional Espresso Machine
Bypass doser malfunctions
Happens when the preground coffee is not ground fine enough, you may have to put the pre ground coffee in a manual coffee grinder to make it finer. The machine is not really designed to brew regular coffee grounds.
Jan 20, 2008 | Saeco Magic De Luxe Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
51 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
