Question about Polaris 800 Twin Sportsman Ride on Toy
I need new tires for my Polaris Sportsman 800 twin ATV
    Genius:
  • Polaris Master
  • 1,508 Answers
Let me know if you still need them i can order them for you
Posted on May 23, 2012
2 Suggested Answers
  • 3 Answers
SOURCE: How do you bypass override switch on Peg per ego
Hey, I found the manual here: http://us.pegperego.com/admin/archive/manuals/polaris%20800_FIUS0802G120_IGOD0510.pdf.
If you're talking about the low and high speed settings, it says there is a screw on the side of the pedal, it's on page 5 steps 51 and 52.
There have been shut off problems with this device that the customer service suggests is due to the battery.  From what I read there are no override switches for this.  I hope this helps.
Posted on Mar 15, 2011
Wont go in 2 wheel drive but switch works light come on dash ?
2004 Sportsman 700 AWD not working..... - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Feb 18, 2013 - Go Back · Polaris ATV Forum > Polaris ATV Technical Discussions > ATV ... AWD wont engage. 2. The instrument / speedo works. 3. The AWD switch is ...Polaris ATV Junkie! .... four wheel drive not working polaris sportsman. Won't go into 4 wheel drive
Feb 1, 2013
4 wheel drive not working
Nov 13, 2011
2004 700, 4WD engages by itself
Oct 28, 2011
4wd is stuck on
Dec 3, 2009
More results from www.polarisatvforums.c
Nov 29, 2015 | Polaris 2004 Sportsman 700 Twin
2006 sportsman 800 twin wont fire at plugs gas burner
If you have no spark , check kill switches for corrosion, does the light work when u turn it over ?
Nov 09, 2015 | Polaris 2006 Sportsman 800 Twin EFI
My Polaris atv' s fuel injector will not shut off, and the engine will not turn over
Do not try to spin engine over, Engine cylinder or cylinders are more than likely full of fuel . Injector is more than likely bad or pcm has got inj. held open.
Oct 15, 2014 | Polaris 800 Twin Sportsman Ride on Toy
Peg Perego 850 Twin ATV does not work
check for 24 volts at the foot pedal, then at the shifter, then at the circuit board, then at the motors
Jul 07, 2012 | Polaris 800 Twin Sportsman Ride on Toy
How to replace 24 volt motor on sportsman 800 twin
you need to take off one of the orange plastic caps in the center of the hub, then bend in half the metal lock washer with a needle nose pliers this should allow you to pull it off, then you should be able to take the washer off, then the hub and the tire and this should give you access to the motor, you'll probably have to replace the metal lock washer
Apr 16, 2012 | Polaris 800 Twin Sportsman Ride on Toy
Tire makes a grinding noise on perego polaris sportsman 800
Why dont u try adding grease to the nuts and screws then loosen the nuts a bit to give air space...try it out
Dec 28, 2011 | Polaris 800 Twin Sportsman Ride on Toy
Peg Perego Polaris Sportsman 600 ATV the reverse does not work. the 1st and 2nd drive work but when placed in reverse it still goes forward. I do not have a user manual would anyone have any answers
remove the battery and black plastic panel and this will give you access to shifter switch, please verify that all of the connecters are connected to the bottom of the shifter switch
Sep 02, 2011 | Polaris 800 Twin Sportsman Ride on Toy
How to calibrate intake valve for polaris sportsman 800
this is the forum for the polaris kids toys, you might get better response in the atv category
Apr 08, 2010 | Polaris 800 Twin Sportsman Ride on Toy
Polaris 800 Twin Sportsman Ride on Toy Logo
113 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
