The air conditioner has been shutting off on its own and now when its on no air comes out of it. I called Maytag service # and due to the bankruptcy of Federers they said they will no longer service the item. help!!! Its only 4-5 years old.
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 04, 2010
MODEL# WGRA-09EZAJS The fan blower and exhaust blower will not shut off and the heat does not come on. We replaced the limit switch but that didn't solve the problem.
Heat will not come on due to open limit or rollout in circuit. This could be due to avoid damage. I advise calling a qualified service tech.
Oct 16, 2014 | Heating & Cooling
Tip
Will Not Shut Off
My air conditioner will not stop making noise, even when it is shut off. I turned it off, and it makes the same noiseas if it was on, but no air comes out until I turn it on. Als, I have to unplug it inorderto stop the noise. Thanks.
J
on Jun 13, 2008 | Maytag M6Q10F2A Air Conditioner
Maytag M6X08F2A air conditioner is not cooling, working as fan
There are many things that can cause your air conditioner not to cool...
heatman101
Sep 30, 2010 | Maytag M6Q10F2A Air Conditioner
Ac comes on compressor runs maybe 3 minutes than shuts off and comes on again. Does this indicate a bad compresssor?
This could be do to low on refrigerant, a dirty evaporator or filter, or a blower not running or not running at the proper speed and a low pressure switch opening due to low pressure. It also could be due to a dirty condenser or condenser fan not running or not running at the proper speed and a high pressure switch opening and shutting the compressor off. It also could be due to maybe a weak capacitor or compressor drawing high amps and the internal overload in the compressor opening and shutting the compressor off, but if that's the problem it will usually take a long time for it to restart, maybe 30 minutes to an hour or more, depending on the outdoor temperature. This really sounds like a high or low pressure issue, but needs to be checked out by a service technician.
Jun 07, 2010 | Maytag M6X06F2A Air Conditioner
Wall-unit Maytag Air Conditioner has power, but nothing else
It' worth a service call. If there is a need to get into the electrical or diagnos a pc boar problem. Good Luck. A tech can probably go sraight to the problem. Ned
Aug 28, 2009 | Maytag M6Q10F2A Air Conditioner
I have a Maytag portable air conditioner (about 5
when the compressor shuts off most of the freon goes to low side(cold) when it starts..it has a lot of freon to move and it works hard and you hear it loud after it has moved most of the freon over to the high side,the sound is less so not to worry it's normal if it clicks when it starts then you worry
9
Aug 20, 2009 | Heating & Cooling
Ac blowing hot air
call service tech to check compressor
Aug 11, 2009 | Maytag M6X06F2A Air Conditioner
Model M6P09S2A Maytag Portable Air Conditioner/Manual?
I have the M6P09S2A Portable unit that is leaking water everywhere. I have to place it in a large bin to keep it from draining on the floor. Any solutions?
Jun 29, 2009 | Maytag NMPEB08F2A Air Conditioner
Maytag Air Conditioner NMPEB08F2A
the blower is not coming on chech for solutions in manual
May 31, 2009 | Maytag NMPEB08F2A Air Conditioner
Unit will not power up at all. receptacle tests good
There are limited after market parts available but you will pay to have it fixed unless you buy a new one..
Apr 26, 2008 | Maytag M7D24E7A Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
