I want to change the code on my adesco safe US65E but i dont know how?
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    I have changed the battery on my TT . The radio is howing safe mode, I know the pin but dont know which buttons I have to press to put it in, can you help??
    IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
    The sequence of programming for Audi TT radio is:
    1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
    2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
    3. By the #1 key you will set up the first safe code digit.
    4. By the #2 key you will set up the second safe code digit.
    5. By the #3 key you will set up the third safe code digit.
    6. By the #4 key you will set up the four-th safe code digit.
    7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
    Dec 16, 2010 | 2002 Audi TT
    How to open a adesco safe if you have combination
    lost combination # i have floor model
    Dec 09, 2010 | Garden
    My automatic vehicle wont change gears
    Sounds like the transmission is in fail safe mode. This occurs when there is a problem in your transmission. You will have to get the vehicle scanned for trouble codes.
    Mar 05, 2010 | 2003 Hyundai Tiburon
    I have sentry safe 350 and need to change code
    http://www.sentrysafe.com
    the instructions are located link above.
    mj
    Aug 31, 2009 | Sentry Fireproof Safe
    S3517sentry safe need to reset
    Press: Program 2x, enter a digit user-code (green led remains on), enter the 5 digit user pin (of your choice except 00000). After 5 digits entered, the green LED turns off.
    May 11, 2009 | Sentry Fireproof Safe
    Resetting Security Code
    Try Nokia MasterCode is:
    5757575216
    This code will reset any security code on your phone to one of your choice.
    that should work if i follow which phone you are trying. if it does not work post the imei number of the phone you need the security code for
    Jan 04, 2009 | Nokia 3110 Cellular Phone
    Sentry Model 1610 Won't Open
    here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
    Jul 02, 2008 | Sentry Fireproof Safe
    jasbo
    jasbo
