We purchased a GE WBVH5100HWW front load washer in December 2005. Recently the boot had to be repaired. Now the machine is pausing when it gets to the rinse and spin or drain cycles. It sounds like its trying to drain but just stays that way. The door doesn't stay locked either. We have to unplug it to stop.
    President:
  • 1,554 Answers
There are two common reasons a washing machine cannot advance to the rinse and spin cycle. First is a clogged drain hose or a faulty,in short draining problem. The water is drained first before the machine spins, therefore no drain means no spin. Check to make sure the drain hose is not clogged/kinked, the pump filter is clear, and the pump is working. Verify drain functions by setting the machine drain only.
The second reason and likely to be the problem in your case is a faulty door lock mechanism. It is a safety feature of the machine not to advance to a spin cycle if the door is not locked. The door of your machine doesn't lock so this is clearly to be the problem. Check wire harness connections both at the door lock mechanism and the control. Make sure the wire harness is intact and fully inserted to both. Replace the door lock and switch assembly (part number WH10X10006) if the there's no issue found with the harness and the connections. You should also check the door plunger and me sure it is intact.
The problem is definitely the door lock and switch assembly as the code signifies. Replace the door lock and switch assembly (part #131763202) to address the problem.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then transfer it to the new doWe purchased a GE WBVH5100HWW - 1a968ea.jpg switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Feel free to update us about the development of the repair. Please make sure to accept the solution that helped you the most. Failure to do so will automatically give credit the first solution no matter how inappropriate or not helpful it is.
Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 04, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Wbvh5100hww washer - no error codes. Starts to fill, then goes straight to drain and skips other cycles. Test mode t08/t09 for hot and cold water valves fails.
There is a strainer in the hoses that are most likely clogged; clean it out and your problem should be repaired. If you still have the errors and you have good pressure coming to the washer, then you will need to replace the water valve on the washer. Here is that part to order. Keep me posted.
Sep 26, 2013 | General Electric WBVH5100HWW Front Load...
Washer won't drain. Cleaned hoses and pump. Motor gets hot and just buzzes.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | General Electric WBVH5100HWW Front Load...
My washer WBVH5100HWW will not fill with water. How do I bleed the air from the water lines?
Any air in the water lines will go on through if everything is working as it should.
Have your pipes froze recently? If so, check the screens in the fittings on the back of the machine where the hoses attach, they may be plugged with minerals. If so, purge the line well into a bucket before hooking it back up.
lp
Jan 11, 2011 | General Electric WBVH5100HWW Front Load...
GE WBVH5100HWW front load washer stops at 1
It appears that you have an electronic control board (directly behind the touchpad) issue. Contact an appliance service company.
Apr 13, 2010 | GE Washing Machines
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Front loading ge washer model wbvh5100hww
I had to have repairman out. He said it had a filter in front panel that needed to be cleaned. It was full of hard white stuff, like caliche dirt. He noticed I use Arm & Hammer Detergent and he said that was good, but don't use HE detergents because when they mix with city water, it causes an odor in washer. Thanks- Beth
Sep 14, 2008 | LG WM-2277HW Front Load Washer
We purchased a GE front load washer in December 2007. Recently the boot had to be repaired. Now the machine is pausing when it gets to the rinse and spin or drain cycles. The pause light starts to flash. ...
ok Problem is not finding out the meaning of the pause button flashing but.......
you need to contact GE directly as this machine is under warranty.
Follow this link. GE APPLIANCE
If they do not help I will just contact me
Jun 05, 2008 | GE Washing Machines
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
