Question about Nikon D70s Digital Camera
Nikon d70 does not want to format
I have tried switching compact flash, batteries, lenses but it seems that the broblem is that it doesnt want to format my card what is the solution to this problem
  • 111 Answers
This camera allows at most a 4GB CF card, are you trying to use something larger, or does it do this with any size card? Also make sure card isnt write protected. Failing either of these suggestions, its possible that something has happened to the card slot internal to camera, they can be quite fragile.
Posted on May 15, 2008
My nikon d70 will not regonize the sd card and gives a format signal
The D70 uses CF (compact flash) cards - I hope you are simply misnaming the CF card. But, if you did use an SD card, it would explain how you could have bent a pin.
I understand that Nikon is moving away from CF cards because of the 'bent pin issue' as well as the limited capacity of the CF card.
So, first I would try a CF card (any size) in the reader. If it still doesn't work, then I think you might check with a camera repair shop. If it is a bent pin, they can fix or replace the card reader. Note that the D70 body can be replaced with an EX rated used body for under $90 at https://www.keh.com/shop/nikon-d70-6-1-megapixel-digital-slr-camera-body-only-9782.html
Thus, I wouldn't pay $100 to have the reader fixed unless there are extenuating circumstances. Good luck.
Feb 06, 2018 | Nikon Cameras
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
Do the Nikon D100 and the D70 share the same in camera Compact Flash unit - not cards - but the hardware to accept and read the CF card? I have a bent pin in the D70 and want to know if I can change out...
I understand what your're looking for.
The D100 is basically an N80 with digital guts. It doesn't share the same chassis as the D70, although it does share the same excellent battery.
Other than that, the D70 was a new design, so it doesn't seem too likely that they would have the same CF sockets.
That being said, unless I had them both stripped apart on the table in front of me, I wouldn't make any bets. It just seems like there would be slight differences in mounting holes and configuration.
Oct 02, 2009 | Nikon D100 Digital Camera
I have a Nikon D70. Camera doesn't read CF.
Sometimes pins inside take strain.  Read up on how to replace the CF pin unit.  Not too difficult as long as you don't force anything and remember to retrieve the little metal strip....
Sep 13, 2009 | Nikon D70s Digital Camera
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
May 28, 2009 | Nikon D70s Digital Camera
Nikon d70 firmware version 2.0
u have card reader stick sd card in that formatt to fat 16 ok for cam if it had hd video use ntfc formatt ok
Feb 02, 2008 | Nikon D70s Digital Camera
Camera read CF card, but cannot see on USB or other media
You can connect the camera to the computer via a USB cable and use the camera as the card reader. It will show up as a mass storage device. You should then be able to copy the images to your PC and format the card once recovered.
Sep 17, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70s Digital Camera Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
