I have a 2004 Dell PC with a Soundmax digital sound card and I'm trying to use Google's new g-mail phone service, but I'm having problems configuring the sound card. I can call out and my external mic works, but not on the computer phone call.
  • Steve Caulfield Sep 04, 2010
    I'm trying to use Google's new phone call option, but my voice isn't coming thru. I have an external mic plugged into the mic-in jack and headphones plugged into the headphone jack. I checked the mic properties and it shows the mic working. I can't find Google's voice and chat plug-in in order to check for mic muting there. Google's talk plug-in is listed in the control panel programs but not in the list of programs on the desktop under all programs and I don't know how to access it in order to check mic muting there.
    Your level of expertise was very helpful.thanks
  • 4,924 Answers
I guess the issue is when you want to call using a direct mic on the computer ..(I believe you attached a headphones...right ??cause the computer do not have a microphone unless it is a laptop with a internal mic..)
If you have the microphone attached..than all you have to do is to double click on the speaker icon in the tasc bar-s tray system (the icons in the right ) ..and a volume controla manager page will appear ..in there look for the mic..and see not to be muted if yo fin it ..if there isnt present ..click the options ..and properties..and from the list tick the case for the mic in and add it in the volumes page ..after that see not to be muted..and raze the volume ..and should be working ..
also check it by making a mic check into the preferences (options) of the software you use to
call..
Another issue is to open the sound max..manager ..and look for speaker configuration ..and in there look for the correct plug for the ..cause its position might be changed..or the wiring can be faulty ..and if you never used a mic..try to see if any position will work ..(change the inlet ) ..
if you are using the front panel ..in lets ..take in consideration that they may be disabled..so try the back pink for the mic in case it seams not to be working ..
If you have a surround %=1 configuration made for your speakers..(3 out lets in the back ..) and you only have a 3 outlets sound card ..than change it to 2 stereo from the speaker configuration of the sound-max manager ...cause this settings cuts out the mic function to use the plug for the 3rd out...
Posted on Sep 04, 2010
  • Catalin Turcu
    Catalin Turcu Sep 04, 2010
    Look for it in the start ..all programs ..and if you installed it ..it has to be there ..unless you never installed the software ..and you just used an on line version ..
    for to be sure ...just run the installer again ..and it will put a desktop icon too..after that open it ..log on ...and check preferences and options under the program ..
    By the way ..check the mic cause it has a switch on it too ..and it might be off..(some of them have ) ..
    Here is a link for Google Talk ..http://www.google.com/talk/
    it also have a video call plug in there ..if you install it it will allow to make video calls as well..
Sound stutters on play
movingwater,
Try uninstalling the driver and then reinstall it back into the system. This may clear this issue up.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 02, 2013 | Dell Dimension 4700 PC Desktop
Dell 8400 - no sound from speakers? Worked in the past.
Should have the hardware driver "soundmax integrated digital audio" Check in device manager and make sure that is what is says under sound, video, and game controllers. If not then you need a audio driver. Go to support.dell.com and put in your service tag and down load the audio.
Another tip is trying to plug your speakers into the front headphone jack. if they work it might be a bad jack in the back.
Make sure the speakers are good and getting power. You can try them on a nother computer or even mp3 player.
Dec 15, 2010 | Dell Dimension 8400 PC Desktop
I have a dell 170l computer and can not get any sound. the device manager says everything is working. i cannot adjust the volume control. the controls are grey and nothing happens when i try to adjust
Goto the Dell website eg. www.dell.co.uk
Click Tech support
Click Home user
Click Drivers/ downloads
Select Optiflex 170L
Confirm
Select operating system E.G .Windows XP
Seect Audio
Select Anolgue Device Drivers
Donload & setup
Lookin toolbar for download progress
The driver downloaded is "SoundMax" To check whether soundmax already exists Goto Run then search soundmax
Good luck, Gwenorm
Aug 03, 2010 | Dell OptiPlex 170L PC Desktop
I bought a used GX520 and the volume does not work. There is no volume icon on the lower right corner. Under sounds and audio devices it says ''no audio device'', and I can't change anything. I own another...
sounds like ( no pun intended) your missing the audio drivers or controllers--right-click on MY COMPUTER then PROPERTIES then HARDWARE then DEVICE MANAGER and check if there are any yellow or red "X"s next to anything (you sound driver) right click and select update driver (you need to be connected to the internet)
Sep 17, 2009 | Dell GX520 PC Desktop
Can't configure audio on my new Asus P5QL motherboard
There should've been something on your ASUS CD that included the SoundMax driver. Without that you won't get audio. You might need to reinstall your CD again making sure you have installed the Soundmax driver. If you can't find it, look for Soundmax on the Internet. If the Soundmax card is properly installed you will see a little blue square on your bottom right task bar. If you click on the little arrow, you can adjust the sound volume. It also contains a wizard to help you diagnose problems.
Oh, you will need to make sure your virus programs are turned off before installing that program as well.
Aug 05, 2009 | Creative Labs Sound Blaster Live! 5.1...
Dell GX280 sound drivers for windows vista
Download Dell OptiPlex GX280 Desktop Soundmax Audio Driver For Win XP/Vista Description: Soundmax ADI 198x Integrated Audio Driver for Windows XP and Windows Vista
Download For XP: R105155.exe
Download For Vista: R145551.EXE
Apr 20, 2009 | Dell Optiplex GX280 Intel Desktop PC -...
Re: inadvertently uninstalled audio on dell lattitude 800
First I'd try to install the latest driver:
1. Go to http://support.dell.com
2. Click on "Drivers and Downloads"
3. Your best option is by using the service tag code (usually on the bottom of the laptop), but if you can't locate it, use the select by model option.
4. Click the plus next to Audio
5. Download the newest driver and install.
6. After installation, reboot and see if it worked.
Feb 08, 2009 | Dell (08701) Sound Card
Installing souund to my computer
i need to install a software for my sound card realtek ac,97
Oct 09, 2008 | Digital Audio OMX-LE (OP428LE) PC Desktop
Computers & Internet Logo
David Payne
David Payne
