Question about Jenn-Air JES9750 Electric Kitchen Range
Jenn-air jes9750aab: bake and broil buttons on touchpad don't work
  • 116 Answers
SOURCE: Oven won't work
It is likely that the safety fues in the back of the unit has failed. This is accessed by removing the back panel of the unit. It is usually located just to the left and up from the center of the back wall. be sure to remove power from the unit before removing the back cover.
Posted on Apr 27, 2007
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Posted on Aug 12, 2009
  • 713 Answers
SOURCE: Oven's bake funktion does not work
Hi,You need to replace the oven igniter. You will find that this is a very common problem with that model and other models that use this igniter. It is very simple to do.
Look inside the oven and you will find 2 screws at the bottom of the oven in the back. Loosen them up and remove the bottom panel of the oven.
Remove the broiler, and oven trays and it is a 10 minute swap out. Removing the above items allows you the access needed to get to the two screws that mount the oven igniter to the burner.
Using either a socket (1/4") or a nut driver, remove the 2 screws and unplug the igniter. The most difficult part of the exchange is unplugging the igniter. The plastic will most likely break because it has become very brittle by being exposed to the heat. Be careful to break only the part that is being replaced.
If you do happen to break the fittings, they can be replaced with any male/female connector. If you need to replace this, I recommend that you stay away from plastic encased plugs.
You then install the ingiter, plug it in, and you are back in business. It is a very simple part to replace, but it is costly.
Thanks and take care
Posted on Apr 27, 2010
  • 842 Answers
SOURCE: bake element burned out on
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
Posted on Jul 26, 2011
Testimonial: "Perfect! it was the high limit thermostat.Thank You for your help"
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
Funny - didn't ask about a slide in electric kitchen range - was asking about my Jenn Air Stove. You deal with them, correct? Have a Jenn Air WW2780B that I can't seem to get working. It started...
I had a customer with the same problem last month and I believe it was on the same model as yours. Let me look in my database and I will get right back to you.
Warmest regards,Richard
Nov 01, 2011 | Jenn-Air SVE47100 Slide-In Electric...
The baking does not work
sounds like the touch pad or main control board could be bad...call for help on checking components....
May 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
My jenn-air gas oven works when i put the broiler on but the oven will not come on
i would replace your bake ignitor, as an oven cycles the broil ignitor and bake ignitor on/off to preheat the oven.. if ur bake is not coming on i would replace it, hope this helps
Feb 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
May 31, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Touchpad buttons dead
Most people don't know there is a 5 year warrantee on solid state electronics. or else i found the part on repairclinic.com. I don't know if they will be cheaper
Nov 07, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air JES9750 Electric Kitchen Range Logo
130 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
