Question about Vacuums
Belt gets hot turns the brush just not as it should what could this be please help
  • 377 Answers
Sounds like the brush is binding around the rod that runs through the center of it. Remove the brush and lean all the debris off from it. Spray a little WD40 on the ends of the center rod and work by hand to loosen it up a bit. When you replace the belt, be sure it is put on correctly.
Posted on Sep 04, 2010
Oreck brush only turns a tiny bit and belt pulley get hot belt not turning much either
If your brush is not turning properly then you need to check the bearing ends to see if there is any hair, string, or thread wound around the brush shaft. If there is and you can remove it, that might fix your problem otherwise I would suggest getting a new brush roller.
Jun 30, 2014 | Oreck XL Ultra Bagged Upright Vacuum
The brush bar will not spin. The belts melt when I turn it on and the belt drive is hot to touch with smoke coming out.
The belt is rubbing the foot plate.Check to see if the foot plate is damaged.Allso check the bearings in the brush bar are free and spin without the belt on.If you cant spin the brush bar by hand with the belt not attached then your bearings are seized.Get a new brush bar
Dec 30, 2010 | Bissell Vacuums
Motor gets real hot on little up right
hi,
f your motor got too hot there is a motorguard switch on there and it has to cool down before it will come back on.check under the vacuum and see if you can turn the brush roller by hand,unplug first.if it turns real freely then the belt is broke.if you can't turn it at all then the brush roller is either jammed or the bearings on the brush roller are froze up.and if thats the case, that will cause your motor to overheat and shut down.if the brush roller and belt are ok then the brushes on the motor might be going bad....
http://www.wikihow.com/Fix-a-Vacuum-Cleaner
.... hope this has helped you... thanks...
Sep 17, 2010 | Vacuums
Dirt Devil overheating Belt Okay
the belt is probably worn , so when the spool turns it heats up and looses friction with the belt.
Jul 05, 2009 | Dirt Devil Featherlite Bagless Vacuum...
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum motor shaft too hot
Check the brush roll ends, will they turn easily or is one frozen. If so, you need to replace the brush roll. If the motor turns on, it and the belt are trying to turn the brush roll and can't. Also check the ends where the brush roll sits in and make sure it hasn't overheated and melted., If it did you will have to replave the base.
Mar 11, 2008 | Dirt Devil Featherlight Bagless Upright...
CHANGING THE BELT
Did you check the brush roll, the ends maybe aren't turning freely. May have to replace it, (Part # R98Z6064) I assume you put the correct belt on it (Part #S01Z6000). Are the sides ok where the brush roll sits in?
Mar 04, 2008 | Vacuums
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
