Question about Gateway FPD2275W LCD Monitor
I have a 22in gateway lcd. when I power it on it only stays on for about 2 seconds. I have replaced a few caps but that didn't fix the problem.
  • 11,361 Answers
May I ask whci caps you replaced, I replace them in a set since bad caps can look normal but can have high ESR.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Capacitors kit:  http://lcdalternatives.auctivacommerce.com/  he can make you a set of caps for you.
Posted on Sep 04, 2010
Pace tech cardiac monitor Fault when power is they LCD show colour line after few second dot blinking on the screen and still same
Bad caps on the internal power supply. Open the LCD and check / replace the bad caps. Fix should be under 20 bucks
Mar 25, 2014 | Computers & Internet
I saw the fix for the blinking power light . I replaced all 8 caps on the power supply board and 2 on the input board. Now the power stays on but no image. The monitor reconises a signal from the computer...
Almost all monitors will accept a 60Hz signal at almost any resolution, however I suggest 1024 X 768 at 60Hz...then you can try higher frequencies such as 75 Hz or more after you have established that the unit is functional.
Feb 11, 2011 | Gateway FPD2185W 21 in. LCD Television
My monitor doesn't want to stay on when I first turn my computor on in the morning. The screen keeps going black after a few seconds. I have to keep turning it off and back on several times before the...
That is a sign of dying power supply due to bad cDC filter caps.
Please read my guide and look at the album of bad caps so you will know what to look for.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 31, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway monitor (FDP1965) Power/video problem
You have a problem with your lcd..get it fixed by technicians...
Aug 28, 2009 | Gateway FPD1975W 19" LCD Monitor
Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Jun 05, 2008 | Gateway FPD2185W 21 in. LCD Television
Gateway FPD2275W LCD Monitor Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
