Question about Vacuums
Wertheim 3280 repair manual for power head - Vacuums
2 Suggested Answers
SOURCE: wertheim model 3280 brushes not
KippaRing shopping centre Vacuum shop undertook to repair the werthmodel - As a result
I no longer require your assistance. I appreciate your responses thank you - Geoff Franklin
Posted on May 05, 2009
Need help with Wertheim Hoover need elescopic hose x
Fixya does not sell Wertheim parts.
Apr 30, 2018 | Vacuums
I want to check out my Wertheim 3180 my daughter borrowed @ it has lost a lot of suction filters are clean
If the filters are clean, try removing the hose from unit whilst switched on, if the sound changes then you may well have a blocked hose or tube
Jan 12, 2015 | Vacuums
Wertheim x3000 motor running but little suction?
Check all of the filters. When there's extra heat, it's usually blocked filters.
If not, dismantle the wand and use long pipe cleaners or a bottle brush to clear any possible jams in the wand or head. Remove the hose from the main unit and if possible, drop ball bearings or marbles down the hose to try and clear any blockage. Remember to recover all of the ball bearings or marbles before you reassemble the hose and wand.
Aug 13, 2014 | Vacuums
Repair wertheim 3180
The hose probably is old enough that it will split repeatedly until you give up and replace it.
Jan 10, 2018 | Vacuums
Wertheim 6035, lost manual, where is button to restart carpet head?
There is a hole at the back of the powerhead near the height adjustment lever. Just put something slender in the hole like a screw driver to reset.
Jul 08, 2012 | Vacuums
Vaccuum cleaner with a broken hose
Is it just the corrugations of the hose broken? With most hose fittings there are two small oval shaped lugs on the side of the fitting. Grab a small screwdriver and gently (you may need a little force) push these in to ease the click ring out.
Once out, you'll find a type of screw cuff. Some hoses just unscrew, some are glued in (use boiling hot water to soften to separate).
Cut the broken piece of hose off, make sure the click ring is still on the hose in the right direction, reaffix the screw cuff, and replace the hose (with click ring) back into the hose fitting.
If it's actually the hose fitting broken, check with your local Wertheim retailer or repairer.
May 20, 2010 | Vacuums
Wertheim model 3280 brushes not working
May 01, 2009 | Vacuums
Vacuums Logo
298 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
