Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Kohler engine backfires but does not run - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Check the key in the fly wheel. Engine will spin on flywheel side but is not turning the crank. Easy $10 fix
Posted on Jun 03, 2012
  • Aaron Jun 03, 2012
Sheer pin on engine shaft is busted. take off the fly wheel and look inside or on the shaft.
Posted on Sep 05, 2010
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
What is causing my 12hp kohler engine to backfire and quit running when given any throttle?
That sounds like either bad (old) gasoline or the carburetor needs cleaning very badly - it's running very lean.
Jul 19, 2014 | Kohler Engine 12hp Cs Command Horizontal...
Kohler backfires
This is a timing issue. Check the flywheel to make sure that it is not loose and that the woodruff key is still present.
May 25, 2013 | Toro ENGINE - 20HP KOHLER Part 93-1169
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
Kohler 19 hp runs then backfires and stalls when heated up
Check that the keyway for the flywheel to the crankshaft hasn't sheared. This is a common problem that throws timing very far off causing backfire and no-starts.
Sep 24, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler k321as engine- misfiring.
sometimes there is a adjustment screw that you can turn just like a car.CAREFUL NOT TO TURN TO MUCH.to burn lean or rich.also you might want to change the fuel and air filter's first,then try to adjust.
May 25, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
606 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
