Question about Honeywell Air Purifiers
We have a air purifier Model 90200 that stoped working. I checked the power supply and the cord is good. I also took a pice of sand paper and lightly sanded the two metal connectors of the cleanable filter. I am not getting any power to the button on top consule
SOURCE: Filter light doesn't turn off after replacing filter.
If you press the function buttons together it will go off. Hold buttons for couple secs.
Posted on Jan 11, 2007
SOURCE: Kenmore Progressive 335
Open the machine and look on the side of the filter. You will find the part number. Sears handles it, too, of course.
Posted on Feb 14, 2008
HEPA Filter Replacement Part No. 83376 and Pre-filter Replacement Part No. 83378
Posted on Feb 25, 2008
SOURCE: blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Posted on Mar 25, 2008
SOURCE: kenmore air purifier- model 85500
Press and hold down the off-timer button and the function button together for about 5 seconds and the replace air filter light will go off.
Posted on Apr 12, 2008
Device appears to have no power. Power cord looks good, it was working the day before then suddenly stopped working... no lights indication of any power making it to the device.
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Aug 16, 2011 | Honeywell (18155) Air Purifier
MyFresh Air Air Purifer is not working. About 1 year ago I accidentaly put a staple through the power cord to the purifer and it stopped working. I have had it in storage but would like to start using it...
You can use any standard computer power cord for this purifier. If the damage is closer to the plug side of the cord, you could cut the plug end off and put on a new replacement plug. You should be able to find a replacement cord or plug at a hardware store. Hope this helps you.
Jan 20, 2011 | Ecoquest Fresh Air Air Purifier
I have a Iceflow Personal a/c . Model #s1357,Serial #04003576; Made in Jan. of 06. The web page is www.sharper image.com. I lost the complete power supply cord. Where can I get one? Thank you for any...
Hi.
To get parts contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read the below, in that case do not get the parts.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 24, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze gp does not work .
Hi.
Check power cord. If power cord has a built in fuse, replace it.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
Regards.
Ginko.
Mar 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Pure Ion will not turn on. We took out the filters to clean them. Wall outlet works for other items. Have tried other outlets.
It sounds like the main board is not getting power. The power supplies have capacitors inside that do overheat and burn out. You can test power coming from power supply leading to main board with a voltmeter. You can try to unplug for 8 hours, in meantime while unplugged, press and hold power button for 5 seconds, then wait 1/2 hour and plug back in to see if unit has reset itself
Oct 13, 2009 | Brookstone Pure-Ion UV Air Purifier
Damaged power supply plug for Zip Connect i Tower
it's +24DC and -24VDC.
the connector is a 4-pin DIN but hard to locate. Older laptops used the same connector. I'm in the middle of fixing two for some local folks here as well, and I can't locate them on Mouser.com. But I do have two older laptops that I may just use the cord from and repair the SI333 iTower supply for them.
Tim
Dec 13, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Thanks and
On this model both sides should come apart. The ioniser plate is glass with metal in it. Soak in dishwashing liquid sollution and rinse thorothly with fresh water and dry completely. clean the contacts that attaches to with a emory coth or very light sand paper. While you have apart inspect all wire connections and if you see a pc board look for any burnt marks. I could not access your email but mine is eboukater@gmail.com.
Sep 28, 2008 | Sharper Image Professional Plus Ionic...
Fresh air won't come on
Check the fuse which is located beneath the cord port
Aug 01, 2008 | Ecoquest Fresh Air Air Purifier
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
Air Purifiers Logo
257 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
