Question about SNK Blackmore Mobile Electronics Blackmore Mobile Blackmore In-dash Multimedia Player and Navigation GPS Units GPS Receiver
Looking for blackmore BDD-T7T wiring harness for a 91 caprice classic
What's the oil and tranny oil capacity of a Chevy Caprice classic 5.0 91
Go to http://www.edmunds.com/chevrolet/caprice/1991/features-specs/ for vehicle specs and http://www.amsoil.com/mygarage/vehiclelookuppage.aspx?url2=1991+CHEVROLET+CAPRICE+E for the capacities you are looking for.
Mar 09, 2015 | Cars & Trucks
1995 chevy caprice classic wiring for crank sinsor
Yup! I just bet you ARE having problems trying to locate the wiring for the crank sensor.
1995 Chevrolet Caprice Classic is only equipped with one of two engines:
4.3L (VIN Code "W")
5.3L (VIN Code "P"
Niether
of these engines were equipped with a crankshaft position sensor.
May 26, 2012 | 1995 Chevrolet Caprice Classic
Blackmore bim-4750 dvd not workig message when parkig brake supplied what do i do
Send me or post a clear picture showing the wire harness (connector with all the wires that plug into the back) fully top and bottom views and I'll tell you how to fix this really easily!
Mar 08, 2012 | SNK Blackmore Mobile Electronics Blackmore...
Tail lights, turn signals, and brake lights are not working on my 87 chevy caprice classic. Bulbs and fuses are good. Thinking it may be the ground wire but need to know where that wire is located...
Look Under the Trunk Matting At Driver side Look For the MAIN GROUND on the Rear Lights Harness, The GROUND WIRE IS EITHER Broken or Has a VERY POOR Connection , You May need to Replace the Connector ITSELF and NO Matter What you Find RELOCATE THE GROUND CoNNECTER HOLD DOWN BOLT to a Spot that YOU Preparer With GRINDING the Mating Surface where the Bole & GROUND WIRES Will Mount. Also Do NOT RULE OUT the JUNCTION PLUG In the SAME AREA Of the Harness Be DURE of >>CLEAN<< I am About 99% Sure of these Being your Problem,Given The Fact that I Have Seen this Literally Hundreds of times
Good Luck With it !
Jul 16, 2010 | 1987 Chevrolet Caprice
Replacing a factory radio on 91 Chevy Caprice
You need to buy an adaptor. You can buy them at Wal-Mart for about 10 bucks.
Mar 22, 2009 | 1991 Chevrolet Caprice
91 chevy caprice classic, engine hesitates,replaced sparks,Wires, distibuter cap, roter button,new EGR valve
Check your fuel filter and air filter. That is usually where your hesitation starts.
Mar 17, 2009 | 1991 Chevrolet Caprice
Fuel injector fuse keeps blowing what is gonig on
check for a naked wire running metal aroun tuns and anywhere that there has been and kind of work done latley pls take time to rate this solution
Feb 17, 2009 | 1994 Chevrolet Caprice Classic
SNK Blackmore Mobile Electronics Blackmore Mobile Blackmore In-dash Multimedia Player and Navigation GPS Units GPS Receiver Logo
158 people viewed this question
Top SNK GPS Experts
Will Halftowaite
Are you a SNK GPS Expert? Answer questions, earn points and help others
