Question about HP DeskJet 1220c InkJet Printer
Colors Murky... HP DeskJet 1120c
I'm not getting pure color output. There seems to be black mixed with the yellow and magenta, and perhaps a bit in the cyan as well. I have cleaned the printer, and changed both the black (45) and color (78) cartridges, only to have it produce the same result.
I have tried to take remove the black cartridge and print a test page, but it won't allow that.
Thank you!
  • 75 Answers
REPLACE COLOUR CARTRIGE.IF THE CARTRIDGE IS DAMAGE ON THE INSIDE THE THREE COLOURS SOMETIMES MIX CREATING A COLOUR WHICH LOOKS BLACK
Posted on May 10, 2010
If black ink is out, will copy in color possible from pc? Also how do I reset this printer?
Dear
Since the model is not found, its difficult to say. however in most cases the subtractive colors are used ie cyan,magenta and yellow. with mixing these white is produced but in case of basic color used ie. red,green and yellow, on mixing these black color is produced. Mostly cyan, magenta and yellow is used hence you can not produce black color so the a complete color print not possible.
Thanks.
Mar 17, 2015 | Office Equipment & Supplies
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I am printing in red but output is yellow
Check the ink levels- it sounds like your Magenta is out- HP deskjets use CMYK to mix the colors- C = Cyan, M= Magenta, Y = yellow, K = intensity (black). Red is usually a blend of Magenta + Yellow- so if you don't have magenta ink in your printer, when you try to print out something in red- it will come out yellow
Jul 01, 2011 | HP Deskjet D2360 InkJet Printer
Dear Sir, I have one HP Color LJ 2500 Printer. Problem is that when I am taking printout all colors are not coming. Red Color and others colors are missing except black one. Model number: C9706A
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Apr 08, 2011 | Office Equipment & Supplies
Prints pink ink only can't get it to do black...
To determine if the cartridge set can produce the correct basic colors, run the "Clean The Print Cartridges" function under Services in the printer driver properties. The cleaning process will produce black, cyan, magenta, and yellow if both cartridges are good. If one or more of the colors is missing:
1. A cartridge has failed or is empty.
2. The print nozzles may be plugged, i.e. dried out or not being cleaned properly by the service station.
3. The cartridge and carriage electrical contacts may be dirty.
4. The printer may have failed.
If there is an incorrect color, the ink is mixed inside the color cartridge.
-- Do not continue until you have worked through any issues revealed above. --
After establishing that the printer is capable of producing the basic color set, print from a software application. If you are not getting the expected colors, consider these possibilities:
1. The software is not configured properly.
2. Uninstalling and reinstalling the printer driver.
3. The printer may have failed.
Go to this web page for more information.
http://h20015.www2.hp.com/en/document.jhtml?lc=en&docName=bpa00224
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | HP DeskJet 895cse InkJet Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Wrong colors
I'm a printer technician... One thing we do see all the time is color cartridges that all 3 chambers are filled with 1 color.
One way to check this is to take a damp lint free cloth (Preferably with distilled water) and blot the bottom of the cartridge and make sure you get all 3 colors to bleed through.
If you try this and still have the same issue, start with uninstalling the software and reinstalling it.
Jul 25, 2008 | HP Deskjet 3915 InkJet Printer
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet 1220c InkJet Printer Logo
115 people viewed this question
Seeker5211
Seeker5211
