Question about Stanley Bostitch F28WWMCN 28° Industrial Framing Nailer And Metal Connector Nailer Combo, 80 120 Psi
Hammer doesn't retract - Stanley Bostitch F28WWMCN 28° Industrial Framing Nailer And Metal Connector Nailer Combo, 80 120 Psi
    President:
  • Stanley Master
  • 1,388 Answers
Assuming there is no air leaking from the gun, the check seal (part #175520) causes piston to retract. It is a band that fits around the cylinder and covers vent holes in cylinder. You can use orings in place of band (or be creative). Other reasons for piston not returning to top include bent driver, worn piston oring, or cylinder/ oring lacking oil. Good luck
Posted on Sep 05, 2010
Testimonial: "Excellent... You were right on the mark. That seal did look bad. Replaced all seals and now works fine! Thanks for your help!"
When I connect air supply hammer comes to tip of nailer, disconnect air & hammer retracts
have you oiled the nailer? if so it sounds as if the trigger mechanism has stuck open.
Nov 10, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
It has always started very hard and doesn't run
Mine is doing the same thing. I took it apart and had to take pliers to get it to retract. Just a cheap part.
Jun 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Nail gun will not fire the nail. Compressor works fine. Hammer doesn't retract enough to hit nail? Cause, solution?
could be a jammed nail in the magazine nose area, bent driver blade or problem with the o ring being worn.
Jun 06, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Seat belt won't retract complete, drivers side
have a look to see if its coiled in twisted as you pull the belt out if the buckle doesn't line straight to the female end well its probely retracted in twisted to repair pull the belt out all the way and then realign the belt its quite hard to do so take your time hope this helps.
Jun 03, 2011 | 1998 Saab 900
Hi I am having problems with my porter cable air nailer.. 2" brad nailer.. The hammer is not retracting far enough to hit the next nail.. I have taken it all apart and cleaned it and re oiled it but...
This is usually a sign that the hammer is slightly bent or the o-ring seal is going bad. You have to replace the hammer. If replacing the hammer doesn't work, the barrel it rides in is out of round and will need replaced. These pull out hard and you need allot of grease and patience to get them back in square to keep the seals intact.
Mar 03, 2011 | Porter Cable PorterCable FNBNNS3TB Factory...
Driver pin on model FN250A not retracting far enough to drive next nail. Will shoot 2 or 3 nails and miss 6 or so.
I had the same problem with an electric stapler from Craftsman after years of disuse. The solenoid that powers the hammer that is no retracting may require lubing if this is possible.
If not, then if the product is within warranty, you might be able to get a replacement.
Jul 04, 2010 | Porter Cable Air Tools & Compressors
Hammer does not retract completely
Usual cause is lack of lubrication. Try really loading the air tool oil into it and pushing hammer back. Cycle it a few times and keep it oiled.
Put about 10 drops of oil a day with heavy use.
Also look if there is a broken nail in the works and clear any jams.
Aug 24, 2009 | Senco Air Tools & Compressors
Plunger want retract
The hammer could just need to be oiled or you could have blown a seal in the gun which is not expensive to fix around 20.00 . A lot of times when my gun jams on a nail it gets stuck so the hammer won't go down. I just use something thin that will fit on the hammer and take a hammer and just tap it back into place.
Aug 12, 2009 | Stanley Factory Reconditioned Bostitch...
How do i get stcuk drums off 1998 chev lumina car
If there are no threaded holes to screw a bolt into to push the drum off....give it a few sharp hits with a hammer.Wear protective googles.
Aug 11, 2009 | 2004 Chrysler Concorde
Stanley Bostitch F28WWMCN 28° Industrial Framing Nailer And Metal Connector Nailer Combo, 80 120 Psi Logo
257 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
