Question about Bushnell Optics
Eyepiece assembly bushnell telescope - Bushnell Optics
  • 3,186 Answers
You never told us what model number or telescope TYPE you own. Is this a refractor or a reflector. ???
If a REFRACTOR usually you have a diagonal, the diagonal goes into the focuser and then the eyepiece goes into the diagonal.
On a REFLECTOR the eyepiece goes directly into the focuser.
Posted on Sep 05, 2010
SOURCE: Cannot see through the lens of a 565 bushnell telescope
Did you remove the lens cap.
This is a simple refractor telescope. Put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x barlow if you have one.
Practice focusing on a distant object during the day time. Read my TIPS on my profile page.
Posted on May 03, 2010
SOURCE: Bushnell 18-1560 Telescope
hi there koosie when using the 4mm eye piece you have to be looking at something at quite a distance hence the power with a 20mm eye piece you can focus closer objects and dont need so much light as the 4mm the more power the more light and furthur away the least power(20mm)the least light and closer you cant focus close with a 4mm eye piece but can with a 20mm
Posted on Jul 17, 2007
SOURCE: Bushnell Deep Space Series 525x 78-9500
The erecting prism can be used for both terrestrial and star gazing-- put it innto the scope first.
The 3x barlow probably will NOT be very useful... it triples the power of any eyepiece. Your small scope cannot go much over 100 power-- before the image degrades.
Put the eyepiece with the BIGGEST number written on it into the erecting prism which you previously stuck into the scope... now go outside during the daytime and practice focusing on a distant object.
The bigger the number on the eyepiece the LOWER the magnification.
Posted on May 16, 2009
SOURCE: Bushnell 114mm reflector telescope, can't see a thing
Probably NOT actually pointed directly at the moon-- you should have moved it around a little -- the moon was probably just outside the field of view through the eyepiece. ........................ telescope must be pointed DIRECTLY at the sky object-- also use the eyepiece with the largest number written on it=== this gives the LOWEST magnification..... and a slightly wider field of view.
Posted on May 18, 2009
  • 273 Answers
SOURCE: I have the bushnell telescope
if it's a reflector telescope (a mirror on one end of the tube and an open end on the other), you point the open end of the tube at your target.
or you might need to collimate your telescope. sky and telescope's websit shows you how to do it. it's under the 'Do-It-Yourself' section (left side of page).
hope this helps :D
Posted on Sep 05, 2009
I need to know how to assemble the eyepiece on a Bushnell 565 telescope?
The eyepiece DOES NOT assemble. It is all one piece. If you unscrew the bottom or the top-- never do this. You must reassemble the lenses exactly.
The eyepiece goes directly into the diagonal (an L shaped device with a mirror inside, and then the diagonal goes into the tube.. That's it. You can buy eyepieces from dozens of different suppliers. Here is one:
http://www.amazon.com/Televue-15mm-Plossl-1-25-Eyepiece/dp/B0001GO15S
Jul 08, 2015 | Bushnell Optics
We just got our Bushnell Voyager 78-9945 Reflector Telescope. It comes with the poorest manual I have ever seen. How do you assemble the eye piece?, what is the little shiny metal triangle piece for? Does...
I think I already answered this question. Eyepieces are NOT assembled they are one piece like this picture:
http://www.amazon.com/Celestron-93342-17MM-Plossl-Eyepiece/dp/B000YKZKNI
They simply slip into the hole of the focuser -- straight in. The larger the number written on the eyepiece the LOWER the magnification.
In the picture above there is a metal triangle holding the tripod legs apart-- it is called a "tripod spreader" or a tripod "tray"-- used for holding eyepieces and other small pieces of equipment while you are using the scope.
Hope that helps you.
Aug 20, 2011 | Bushnell Voyager 78-9945 Telescope
Bushnell 78-9003 telescope purchased at yard sale with no eyepiece. Where can I purchase one that will fit? It talks about a .965 inch eyepiece.
.965 eyepieces are readily available on ebay. A meade 25mm MA (modified achromat) is about $10 plus shipping This will give you 700mm/25mm= 28x power. Avoid any eyepiece marked with a H (Huygens) as they have terrible field of view.
.965 is not a popular size anymore and Bushnell does not make very good telescopes. Don't get frustrated, if you are still interested, buy a Meade, Celestron, Orion quality telescope.
May 15, 2011 | Bushnell Deep Space 78-9003 (525 x 76mm)...
We are unable locate a manual for a Bushnell telescope 78-4620B. cn yoiu direct us pleaase?
All of Bushnell's manuals are on this web site:
http://www.opticsplanet.net/bushnell-warranty.html
Remember that the manual will only have assembly instructions. It will not teach you how to focus, what eyepiece to use, or how to find objects in the night sky.
Locate a local astronomy club and the members will help you once you have assembled the telescope.
Jan 06, 2011 | Optics
What is the lens arrangment in the eyepiece of an 18-1560?
Did you DIS-assemble the eyepiece? If you did no one can tell you how to put it back together.There are so many different eyepieces. Normally the eyepieces just slip into the focuser.
Jun 05, 2010 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Need eyepiece & triangular tray for Bushnell 78-9669
Bushnell has a customer service web site here:
May 22, 2010 | Bushnell 78-9669 Telescope
I need a full instruction manual for the bushnell banner astro 400 78-5100 telescope
Look down this web site page for your model telescope:
Dec 11, 2009 | Bushnell Optics
I need an eye piece for a Bushnell AK-78-9440 Telescope
Eyepieces are either .965 inch or 1.25 inch in size. Measure the hole. You can buy eyepieces from many on line astronomy shops. Here are two:
http://www.agenaastro.com/Telescope-Eyepiece-s/3.htm
http://www.optcorp.com/
Oct 09, 2009 | Bushnell Voyager 78-9440 (440 x 12.5mm)...
Bushnell Deep Space Series 525x 78-9500 We didn't assemble when we received as a gift a couple of years ago and now realize that the assembly instructions were left out of box. We assembled telescope but...
Apr 13, 2009 | Bushnell 525x Deep Space Reflector...
Eyepieces not fitting into 90-degree penta mirror
Here's the link to the user manual if you need it; http://www.bushnell.com/customer_service/manuals/telescopes/78-9440_Voyager.pdf Check the bottom of page 3, I think it answers your question - eyepieces should insert directly into the penta mirror. check page 9 for a diagram showing the whole assembly. If it turns out you have the wrong eyepieces, you can contact bushnell's spares department on; http://www.bushnell.com/customer_service/partsinfo.cfm?section=General%20Use Hope this helps, please ask again if you need more info :)
Sep 15, 2007 | Bushnell Voyager 78-9440 (440 x 12.5mm)...
Optics Logo
184 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
