Question about GE Dishwashers
Water want pump out. sink is not cloged - GE Dishwashers
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 04, 2010
Water left in dishwasher at end of cycle
Probably a bad or cloged pump. If the discharged water goes to a garbage disposal system then try to remove the hose from the dishwasher and see if it is cloged. This is what usually happens.
Good luck,
Marty
Mar 24, 2014 | Whirlpool WDT710PAYM Gold Series...
The sink wont work and cloged up
1. Fill some water in the sink. 2. Try using a plunger to force air and water down the drainhole. Hope it works. Use household bleach to clear the drain pipe.
May 17, 2013 | Home
Water was not pumped away, cleaned everything, but power is off and cannot switch the dishwasser on again
Hello when you stated water is not pumped away and that you cleaned everything and now the power is off did you check the float switch in the unit? If the water was not pumped out of the dishwasher then either you have a clog in the drain line either where it goes into your disposal or sink area or in the drain line, or the pumps impellar is not spining or something is cloged in the pump stopping the impellar from moveing. I would first look at the float switch in the unit this is a small switch that tells the unit to either add water and start your cycle or drain water and finish the cycle. I will await your reply as to you finds before diagnosing further. Thank you
Rick
Nov 19, 2011 | Miele G 1470 SCVi Built-in Dishwasher
Will not pump out water
ck your drain hose going to sink take lose make sure its not plug up even look where it goes in the garbage dis. or take cover of in botton diswasher, some time it get cloged.
Apr 11, 2010 | Frigidaire 18 in. FDR252RB Built-in...
My dishwasher does not drain
pump out or timer not sending siginal to pump motor... or drain line cloged or kinked or plug left in disposal at sink if you just had a new disposial put in
Mar 29, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The water will not drain and the spin cycle will not work.
Open bottom of machine and check the drain pump to make sure it's not clogged.
Mar 12, 2010 | Washing Machines
Water shoots out of the water diverter or overflow on the sink but its not cloged
Yoou must be talking about the air gap for dishwasher discharge hose. This will show water if the inlet to the disposal is clogged and the water has a hard time getting through the inlet (it is a common problem). The problem is not with the dishwasher, Disconnect the rubber hose end to this outlet and check the inlet piece and check the hose that you just removed; you should see something clogged. Goodluck ,Macgivor.
Nov 20, 2009 | Whirlpool Dishwashers
1996 Jeep Cherokee Boggs Down Like it Out Of Fuel
sounds like a fuel pump like my 96 you want come help me do mine i had same problems ebay sells them for 100 bucks
What happen the gasket rotted at the top the pump and cloged the pump you can try magyver it like my friend did pulled the pump out the tank and labels all the wires and sprayed out the pump with air hose and water. ore just get new fuel pump like i did
Jul 13, 2009 | 1991 Jeep Cherokee Briarwood
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
