Question about Kyocera Mita FS-1920 Laser Printer
Call service 7400:0199014 What has happened to printer
How to service ink jetprinte
A generalised service would be to run a head clean, alignment, physically clean the printer inside and out. Also replace the cartridges. Some printers can be maniputlated with servicing software if you can get the right software for your printer. This allows you to reset counters, look at the printers overall use, that kind of thing.
Mar 26, 2014 | Office Equipment & Supplies
My printer cannot scan
Copy is happening? if copy is happening, check for the OS support, reload the drivers with original CD..If copy is not happening, fault with scan camera,replace it or else submit the printer in service center..
Dec 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Canon mp630 printer - error 5100, says to turn printer off then back on again. This is happening every 1-3 printed pages and also happens while printer is sitting idle.
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
You can also reset using the service menu
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
If the timing strip has stuff on it the reset in the service menu will not fix it.
Apr 20, 2011 | Office Equipment & Supplies
When I go to print a page or what ever off my computer the printer says its printing but nothing happens
there a windows service as spooler service, must be as automatic and working. Normaly if this service has stoped for any cause, then the printing service, is blocked
Jan 05, 2010 | Dell 926 All-In-One InkJet Printer
PRINTING RED LETTERING INSTEAD OF BLACK. REPLACED
well you need to clean up ur printer it just needs a little bit of servicing , it happens when the printer is dusty because of which the sensors are blocked and because of which this problem happens...it happened in my computer..
Nov 06, 2009 | HP DeskJet 6540 InkJet Printer
Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Aug 05, 2009 | Konica Minolta Magicolor 4690MF...
Printer goes offline for no apparent reason
I don't know if you've tried this already so please forgive me if you have:
I don't know what OS you are using, so I'll presume you're using Vista. Type Services into the search bar and open it. (In XP you click Run, and type services.msc)
On the Services Window, scroll down to Printer Spooler. Right-Click on it and Restart or Refresh it.
Now try and print something.
Let me know how you get on with that!
Chris (ziraffa)
Jan 16, 2009 | HP Photosmart D7460 Printer
Message on screen printer in use when it is not....
I would do the following:
1. first try to restart the printer spooling service (go in to the services applet and look for print spooler and restart the service. then test.
2. I would uninstall the printer and driver (disconnect printer and delete the printer from Printers) then reinstall.
Hope that helps
Dec 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Printer MP160 service error 5010 after refill catridge
I had refilled the catrige, then when I start to print a 'service error' window will appear. At the LCD screed shows E.. 4 ..2. I believe the printer simply assume the catridge is depleted, but how can it happened as I already just refilled it.
How to make printer detected the catridge as a full? I really hope you can solve and make my refilling mission succesful and my printer work again.
Aug 13, 2008 | Canon PIXMA MP160 All-In-One Printer
SERVICE ERROR 5100
please suggest me service error 5100, when i start to print it appear service error 5100. what happen ?
Jul 05, 2008 | Canon PIXMA iP1600 Printer
Kyocera Mita FS-1920 Laser Printer Logo
245 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
