Question about Quasar HQ2052UH Air Conditioner
I have a Quasar Cool Look A/C Model# HO2051NH. I have it in my front window which is about six inches off my living roo floor. The back of the unit is completely outside the window and the front whre the air comes out is inside the apartment as it should be. I discovered (too late that there was condensation or water slowly leaking from the bottom of the a/c that was inside the apartment. It looks like it migt be coming from a round hole. Am I missing a an exhaust tube or maybe something is cracked? I'm pretty sure this shoudn't be happening! Any suggestions on how to fix it? Thanks!!
    Guru:
  • 642 Answers
The unit should be slanted slghtly downward toward the outside of the room to allow water to run to the outside. I doubt there should be a drain tube on the inside of the room. Lok at this link for some general pointers.
http://dl.owneriq.net/2/2dca85dd-1381-4d1d-a2ed-08e8ffd24fe6.pdf
Posted on Sep 04, 2010
Thermostat
Add a comment and describe brand, type and model of product. And what this product does. Is this a thermostat?
Also say if this is new installation or older installation
If you have Honeywell thermostat, then model number and AA battery are located on back of device. Replace battery.
Web search your model number and include .pdf in search parameter to obtain product manual, Use Ctrl+f to word-search manual for troubleshoot section. And view manual for illustrations showing location of battery.
Apr 25, 2013 | Honeywell TH5110D1022 Focus PRO 5000...
My crosley air conditioner is leaking from the front. There in nowhere to drain it from the back. help
Hello, if this is a window unit make sure it is tilted back in the window about a 1/4 inch. If the unit does not have a drain then it uses the condenser fan blade to scoop up the condensate and splash the condenser to cool it and evaporate the condensate.
Jul 12, 2012 | Heating & Cooling
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Quasar cool look hq2061fh
Hello, some window units do not use a drain tube instead they use the condenser fan blade to scoop the condensate from the bottum of the base pan and splash the condenser coil to keep the condenser cool and also evaporate the condensate. Most of the time you can hear a "swishing sound"
Jun 19, 2012 | Quasar HQ2052UH Air Conditioner
My attic air conditioner will stay at 81 degrees in the hottest part of the day only when it is sunny when it is cloudy it works fine I have a small 900 sq foot ranch
if the difference in termperature is between 15 and 20 degrees between the inlet and outlet, the unit is doing all it can and is undersized. if not check for airflow problems, filters, dirty coils etc. and if that is all good, then there may be issues with the refrigerant charge
Jul 12, 2009 | Dometic Rooftop RV Air Conditioner
Picture freezes and turns its self off and then turns back on
this happened to me with my RCA Sceium 52 inch floor model, for 2 years before I figured out it was
over heating. Of course I had no money to fix problem. What I did is simply put a cool fan on back
or AC. Even rolling in front of a sliding glass door when its cool out will work well. Cold air on back
will stop it from turning off.
Good luck
Apr 26, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Can not remove microwave from wall
There should be screws in the cabinet floor ABOVE the microwave. Unscrew them, they will be long. Make sure you have someone to help you hold the microwave while you unscrew. One all the screws are gone, unplug the microwave and tilt the unit front first down about 45degrees then lift the back of the unit up 1-2 inches. Pull it forward and you should be all set.
Dave
Apr 20, 2009 | Microwave Ovens
How many BTUs needed to cool a porch 6'x15'x9 w/ lots of glass?
where do you live?  without further knowledge I'd say 16-20k BTU.
Mar 15, 2009 | Heating & Cooling
Quasar window air conditioner
Air conditioners remove moisture from the air. The water collects in the base of the unit. Under normal conditions this water will be evaporated out of the unit. However, it is possible for some water to sit stagnant in the base of the air conditioner for extended periods of time. There is no easy way to prevent this problem. The problem will be reduced if you carefully clean the base of the inside of the air conditioner at least once a year. That will keep any dirt, lint or dust from absorbing the water and allowing mold and mildew to grow. Also, replace the filter behind or in the front cover.
also check the drain ,to make sure its draining properly If this helps please give me a fix ya vote
800-269-2609
Contact Us
8 am to midnight-ET
Seven days a week SHOP WITH CONFIDENCE redarrow.gif Secure Shopping redarrow.gif Shipping Guaranty redarrow.gif Return Any Part redarrow.gif Free Repair Help redarrow.gif PartDetective® redarrow.gif Part Warranty redarrow.gif Great Prices redarrow.gif Privacy Policy redarrow.gif Testimonials transparent1.gif toolbox.gif
Online help from the RepairGuru®!
Jul 14, 2008 | Quasar Heating & Cooling
Quasar HQ2052UH Air Conditioner Logo
348 people viewed this question
Top Quasar Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
