Question about Samsung L200 Digital Camera
How do I unlock a card when I try to take a picture?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 04, 2010
Testimonial: " Thank you so much. It was the card that was locked. I have unlocked it and now it is working. PC"
My fujifilm finepix jx 300 says protect card even after sliding the switch on memory card to unlock
check if in the card slot is any debris. You could try to clean the contacts of the xD memory card with a dry cloth. Place the card on a flat underground and press firmly on the cloth. Don't press without a flat underground, because you could easy break the card.
It also could be some of your pictures are protected. You have to unprotect the pictures first.
Nov 15, 2013 | Fuji FinePix A303 Digital Camera
Tip
How to Unlock SD Card
<p>Many times people do not realize that a <span style="font-weight: bold;">SD card</span> can be <span style="font-weight: bold;">write protected </span>or locked. They will <span style="font-weight: bold;">try to download pictures</span> or <span style="font-weight: bold;">make changes to the pictures </span>and the <span style="font-weight: bold;">SD card will not allow</span> them to do it. The little lock feature on the side of the card will <span style="font-weight: bold;">write protect the SD card</span> so that changes cannot be made. You will need to <span style="font-weight: bold;">unlock the SD card</span> to be able to make the changes that you want to make or download anything from it.<br /> <p><br /> <br /> <p><span style="font-weight: bold;">To allow the SD card to be accessed</span> is a simple as sliding a small tab on the side of the card to the <span style="font-weight: bold;">unlocked position</span>. Usually this means sliding the tab towards the back of the card and away from the front of the card. The card will have to be removed from the <span style="font-weight: bold;">camera</span> or <span style="font-weight: bold;">PC</span> to be able to do this.<br /> <p><br /> <br /> <p>Here is a <span style="font-weight: bold;">picture of an SD Card</span> and you can see the tab on the side of the card. It clearly shows you what is the locked and unlocked positions on the card.<br /> <p><br /> <br /> <p><img src="heatman101_2.jpg" /><br /> <br /> <p><br /> <br /> <p>This feature can be very useful to make sure that you do not inadvertently <span style="font-weight: bold;">erase data or pictures</span> from the card. If you have children viewing pictures on the SD Card make sure to lock it before allowing them to play around to make sure that they <span style="font-weight: bold;">do not erase your pictures</span>.<br /> <p><br /> <br /> <p>As you can see this is a very good feature to have and it will be very useful to you, but you do need to remember to unlock it before trying to make changes to the card.<br />
on Apr 21, 2011 | Cameras
My SD card is locked and i cant get it unlocked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 24, 2011 | Vivitar ViviCam 5024 Digital Camera
My memory card is locked am not given lock number how to remove lock 2gb micro
Look closely at the memory card itself. There should be a tiny picture of a lock indicator on the card and a little tab to click or move to the lock position. There should also be a picture of an unlocked lock to signify which direction you need to move that little tab in order to unlock the memory card. Try sliding it to the unlock position to solve your issue.
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
When we try to take a picture, we recieve a "Card
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 11, 2011 | Vivitar ViviCam 5024 Digital Camera
I have a powershot SD 790 IS.When i turn the camera on i get the message Card locked.How do i get it unlocked & can my pictures still be recovered? Thank-You Maurita reit_24@yahoo.ca
Take the card out of the camera, on the left hand side, you should see a small notch you can slide to lock and unlock. Slide to the unlock position.
If its already in the unlock position, re-insert it and check the camera - card setup menu, you may have picture protection enabled..
Once accessed you will see which pictures have survived, the only problem I can fore see is that you tried to take pictures while the card was locked, in this case, none will survive.
If you think there are files which may have been deleted, you could download and install "recuva" from "filehippo.com" then try to recover deleted files, but be sure to recover said files to a new destination ie a folder on your PC. If you recover back to your card, you will overwrite the very same files your trying to recover.
Mar 11, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
My my son removed my memory card from my computer without first asking for it to be removed. All my pictures are now on the card and I can't open it. How do I unlock the card?
Welcome to FixYa
Whats Showing when Trying to Open Pictures in Card.You can Open it by Putting card again to PC to view pictures.
If card is Damaged then you cant see it any more...
If card is LOCKED-It need to be Unlocked with Unlock device-then All data will be deleted..
I dont think it is locked....ONLY by just Removing from PC -card will not be Locked...
You can Open it manually...Let me know if you need further assistance...
Thanks for Connecting FixYa..
Aug 31, 2010 | PNY 2GB microSD Memory Card
When trying to take a picture it says card locked.
The SD card lock/unlock switch has been moved to the lock position. Remove the card and slide the switch (along the edge of the card) to unlock. If it is in unlock, try sliding the switch back and forth a couple of times. Reinsert the card and it should be ready to go.
Apr 06, 2010 | Samsung Digimax S500 Digital Camera
My memory card locked! i need to know how to unlock it
There is a small switch at the base that needs to be moved to the "Unlocked" position. It's at the side of the card.
Mar 26, 2009 | Cameras
Jazz-Hdv178
Did you unlock the SD card or accidentally lock it again?. There is a switch on the SD card to unlock it. Try this and then let me know how you make out.
Aug 29, 2008 | Jazz DV-179 Digital Camera
Samsung L200 Digital Camera Logo
87 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
