FixYa.com
Tags:
LG DLE3777 Electric Dryer
What do I need to do if the dryer cord and terminal...
posted by tanghonglai on May 11, 2008
I have used my dryer for 2 years with no problem, then all of a sudden I saw a spark in the back and came to notice that one of the wire has burned out, do I have to replace the whole thing or is there a safe but less expensive alternative?
Thank you!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 18, 2008
Not Rated (0)
Sgt 48
Rank:Guru Guru
Rating: 88%, 87 votes
I would check the terminal block where the cord is connected. If they have become loose, this may be the cause of the sparking, I have also seen some the wires come in contact with the drum and be worn through. Turn off the power then do your investigation.
Sgt 48
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 11, 2008
Not Rated (0)
Junoon007
Rank:Wiz Wiz
Rating: 81%, 76 votes
Hello sir,
I think this is voltage problem. At the time of using u received high voltage of current so it burns.It can be repaierd. Just replace that particular part only. Go to authorized service center and replace only that burned part.
thanks
Don't forget to rate the solution
Can you Help with these Dryers problems?
Dryers
Hotpoint vtd00p tumble dryer.
Hotpoint vtd00p tumble dryer. ... Answer This...
Dryers
Getting E62 error
Getting E62 error Answer This...
Dryers
dryer model drcs68w start light
dryer model drcs68w start light... Answer This...
Dryers
hotpoint aquarius ctd00 blows...
every time i plug it in it... Answer This...
Noisy dryer
Hi I have a lgdle3777w and it... Answer This...
Repair Service
Find Dryer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
