Can not get printer to print it is plug up correct
    President:
  • 2,712 Answers
Have you installed the printer driver and set it up as your default printer?
Posted on May 11, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Printer prints rubbish but test page is correct
Power off printer. and unplug USB cable, Go to control panel and uninstall all related software.reboot PC.
Go to printer Manufacture website and download latest version of software.
install software. do not plug in the printer until told to do so.
Hope this helps
Mar 01, 2013 | Epson Stylus Multifunction Inkjet Printer/...
Trouble printing wirelessly
Make sure the paper size and the tray you choosing correctly in printer properties.
Jan 28, 2010 | Xerox Phaser 3124 Printer
TM88IIIR on XP machine prints garbage
Turn printer off hold down on feed button and turn it on. This will produce a test page. Compare all your settings to the port settings that it is plugged into. It sounds like a buffer problem.
Jan 14, 2010 | Epson POS TMT88IV Thermal Receipt Printer
I just bought a new HP desktop computer and connected my old HP PSC 1401 printer. I installed the printer. When I try to print a file it sits in the print queue and does not print.
Your new computer has not installed the drivers correctly or you have the wrong printer selected. Start by uninstalling all the printers then install the driver from the hp website use the correct operating system, then plug printer into computer when the software tells you too.
Nov 28, 2009 | HP Office Equipment & Supplies
I just purchased a C540, color laser printer. HOWEVER, in setting the printer up, and trying to print anything, the printer won?t print. Nada. Seems as if there is no communication. Everything is plugged...
u have to installed driver first in your PC then after cheak your printer installed correctly go in control pennal open printer option see there there was showing your printer if u have installed correctly then after right click on it then set is as a default printer then try to print
Nov 15, 2009 | Computers & Internet
Was printing fine. I turned the printer off and it won't go back on. Everything is plugged in correctly.
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
May 03, 2009 | Epson Stylus Photo R800 InkJet Printer
HP 4550 will not print graphics
This printer will work with Vista. I use the driver that Vista provides with the standard HP internal network card and it works fine. Try putting your network card back in and undoing the USB adapter changes. Then just go in and add it back with the "Add Printer" wizard.
My compliments on the 4550, though. It's a great printer. A bit slow compared to what's out there new, but a workhorse that will last nearly forever.
Feb 12, 2009 | HP Color LaserJet 4550 Printer
Failure to comunicate with printer
Do you have your printer directly plugged into the back of your computer? When you installed the printers software and driver, did your system recognize the printer directly plugged into the back of your computer. If you are running XP with plug and play, it should recognize it and install correctly. Try doing a test page after installation. Also, if your ink cartriges are not installed correctly, it will not let you print. Also, make sure your photo software is pointing to your printer as a default.
If this helps you, please rate me.
Dec 19, 2007 | HP OfficeJet 6110 All-In-One InkJet...
jasbo
jasbo
