Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
FLASHING LIGHT ON THE PC AT THE POWER ON BUTTON---SYSTEM WILL NOT POWER UP
    Scholar:
  • 50 Answers
Sounds like Faulty RAM modules, Open the box, and Try removing the Memory and re-inserting it, if that does not work, try one at a time and start the machine..**Make sure u close the Box before powering on. It could be bad Memory (RAM) module.
see link to see how to open and check the memory modules:
http://qwickstep.com/search/view-answer/how-to-open-dell-dimension-5150.html
See here for complete list of Beep Codes:
http://support.ap.dell.com/support/edocs/systems/pmac2cm/en/en_ug/error.htm#system_flash_codes
Posted on Oct 13, 2010
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Compac d-530 won't start red light under power button flashing
Take out the battery and only hook up the AC Adapter. Try turning on your laptop and if you still only get a flashing power button then try another AC Adapter. If the same thing happens then that means the motherboard is bad and would need to be replaced.
Feb 05, 2012 | Computers & Internet
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Don't starts yellow light flasing
If the power button on the tower is flashing Amber, the fault is the power supply. Replace the power supply and they system should work.
If the power supply doesn't resolve then the 2nd most likely failure is the Front IO panel (Circuit card behind the power button)
Nov 22, 2009 | Dell XPS 400 PC Desktop
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
No power to my computer.
hi
stuart
just read this carefully.................
Unplug the power cord and the display cable from the monitor. Now press the power button for 60 sec exact. Plug the cables and your system is working................ This is just a power drain.
Enjoy
Jan 13, 2009 | Dell DimensionTM XPS 710 PC Desktop
Power is shutting down with orange light flashing on t
Hi, This is na very common problem with these Dell machines. I have found one of two things are the cause of this.
1. Your memory warms up once system is on for a while and fails to make proper contact on all pins, focing system shut down (after which only a power disconnect will restart system).
Solution. Carefully remove memory moduls and wipe copper contacts gently with a damp cloth after which you can replace the modules firmly. make sure power to the system is uplugged during the entire peocedure and give the system 5 minutes after putting modules back (just in case moisture from wiping remains).
2. Your PSU (main power supply) is failing. Replace PSU (cost around $50 at local IT shop).
cheers
Jan 13, 2009 | Dell OptiPlex GX280 PC Desktop
E-Machine T2984 the power light is flashing.
There something problem in your PSU, you need to check the power supply of your system, if hard for you then you can let repairman do it, or replace that with a new one.
Jan 21, 2008 | E-Machines eMachines Desktop PC
Red light
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
OR
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Jan 02, 2008 | HP Compaq Business d530 PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
155 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
