Question about Frigidaire Affinity ATF7000E Front Load Washer
We have a pump that's clogged - Frigidaire Affinity ATF7000E Front Load Washer
  • bradford49er Sep 04, 2010
    we can't get the bottom off of the washer to access the pump, any thoughts on how to get it off???
    Genius:
  • 1,075 Answers
Do you know ive worked on washing machines recietly to improve them and it shocks me to find a machine that clogges.ive studded fibres and parts and find it hard to believe that anything can get past the drum,a small plastic pipe under the drum is the problem.adrian,infact please tell me the outcome as i would like to know.adrian,,
Posted on Sep 04, 2010
Power flush
You have a clogged filter, clogged lines or clogged pump. Did you try to do this with the oil cold? If so, the pump has to work MUCH harder and may not pump.
Clean out the oil from the entire system, looking for clogs. Manually filter the oil and pour it back into the system and try it again.
May 12, 2014 | Pitco Frialator Kitchen Appliances -...
I have a little giant submergable sump pump and its not pulling water the motor keeps getting hot How to fix it?
Check the discharge hose to see if it is clogged or kinked. If you disconnect the pump from the hose, does the pump operate normally? Check the bottom of the pump to make sure the pump intake is not clogged. If no clogs are found, and the pump does not work with the hose disconnected, it is probably the pump. Depending on the age of the pump and the pump size, it may need replacement.
Apr 11, 2014 | Plumbing
Front washer motor not engaging, rear washer works
washers.
hits electric and water hydraulics, so 2 technologies merge.
1: fuses blown?
2: does pump motor spin when asked, (2 men or kit and you)
yes, good
no, ? bad, pull hose, spin now,
yes, line clogged
no? pump dead, or clogged clean pump or replace, your call.
if pump seems dead i check for 12vdc at pump on demand.
kid turns switch and 12vdc lands on motor pins.
got 12v, good.
so pump spins, and no squirt.
A: the line is long, very long. and can clog easy due to that fact
or the jet on the end is clogged.
so why no remove the hose. does the hose squirt on demand.? at rear of car>?
yes, nozzle clogged.
no,,, line clogged. big work finding long hose line.
some lines near front of car (hoses) have check valves.
they too love to clog.
there you go, washer 101.
Dec 16, 2013 | 2007 Toyota Highlander
I have 2004 Suzuki Grand Vitari. Washer light stays on when bottle full and rear washer not now working. Any idea please ?
pump working , just because it make noise, doent make it good.
1 clogged or damage pump impeller. (pump may have tank screen, it too must not be dirty)
2: clogged line.
3: clogged in line check valve. (tiny) usually found close to pump. within 1 foot or so. most cars.
4: clogged jets, if both fail , see above. rear has 1 so.... clean it.
you can test the pump attach a new line to just pump, turn it on
and see if it squirts, good, and hold finger over end, does it have good pressure? yes, then it is good. sound be darn.
if pump good, fix the line clogs.
easy stuff here.
using air pressure (shop air) at pump end of hose, see if you can flow air end to end. yes?
Feb 22, 2013 | 2004 Suzuki Grand Vitara
It will wash but when its time for the first draining out the water to spin it stops
Three things to inspect are:
  1. Clogged drain hose - cause water to back up to the pump and shut down
  2. Clogged drain tube - usually occurs when the drain hose is attached to a drain tube that empties out into the homes sewer system. Just like a clogged drain, water will back up all the way through the drain hose into the pump and shut down.
  3. Clogged or bad drain pump - Many times, debris left in pockets will work it's way into the drain pump. Over time, enough debris (paper, coins etc) could lodge itself into the pump. When the machine tries to empty or spin out, the pump becomes overwhelmed and shuts down. Sometimes, you may even see a puddle of water appear under the washer due to a clogged pump. This can also happen if the pump itself is worn out and no longer working up to specifications.
Best of luck with your repair.
Greg
Jul 20, 2011 | Kenmore Washing Machines
The water does not drain I check for clogged lines and they where not. could it be my drain plump si shot
You did not indicate that you pulled the pump filter to check for a clog or restriction. If you did not pull the filter out then I recommend that you follow the steps shown in this image to pull the pump filter out and check for a clog or restriction in this area. Since the tub drained using the hose beside this filter then it is likely that a clog or restriction in the pump filter is causing your drain problem. If you find no problems in this filter then you could have an undetected clog in the drain hose or you could have failed/clogged drain pump. If the pump is not running in the drain mode then you could have a failed control board or a wiring failure.
Jan 09, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water not pumping
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat.
Please post back for any further assistance.
Daniel
Aug 07, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
My hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Sep 29, 2009 | Hayward 1.5 Hp Northstar High Performance...
I have "nd" displayed
You need to check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump. Sorry for your trouble and I hope this helped. Best wishes.
Sep 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washer is showing code F 02 hose is not clogged what else can i do?
If the drain hose is not kinked or clogged, then the pump will need to be checked. Remove the hoses from the pump and use a flashlight to look into the suction port of the pump. Look for anything clogging the pump (like the occasional stray sock). Check the pump impeller and make sure there are no broken/missing blades and that the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just something clogging the pump or jamming the impeller. Sorry for your trouble and I hope this helps. Best wishes.
Aug 29, 2009 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
