Question about Kenmore 22622 Top Load Washer
My washer machine does everything but dont drain
  • Kenmore Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Posted on Sep 04, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Capri washer
Commonly the drain pump is run by a belt drive, which has possibly broken. You should be able to take the back panel off the washer by undoing several screws, and then look to see if anything is obviously broken.
Aug 24, 2013 | Washing Machines
How to get to drain pump from bottom of washer
its pretty easy really but you must reinsert the stabilizer bolt before you move it.unplug and drain everything. remove inspection panel on the rear and the pump is plain to see its the thing all the hoses are coming from. usually its a nickel stuck in there where the intake hose is. TIP! take pics as you go with dig cam or cell so you dont get lost in the woods good luck you can do it!
Oct 15, 2011 | Maytag MAH2400A Front Load Washer
It does everything but it will not drain.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Roper RAS8445KQ Top Load Washer
The water wont drain out of the washer everything else works but the water wont drain
you need to check the drain pump for a restriction.
if you have a wet dry shop vac attach it to the end of the drain pump and remove all the water.then look at the hoses that are attatched to the drain pump remove them and look for any obstuction.
if you do not find any thing then you might have a faulty drain pump make sure to check the elctrical connections.'
there might be a problem with the door lock but at this time dont think so
Apr 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine stopped working and water will not drain
if washer does not spin then you need to check lid switch. if just not draining but everything else is ok then drain pump is restricted. check for restrictions in drain hose
Jun 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Frigidaire front loader (about 14 months old) won't drain. It hums (or buzzes) loudly and does nothing.
you really need to tell me a little more;is the drum turning does the machine wash other than this hum is everything else ok?I would say there might be a sock or simler stuck in your drain pump as i dont have enough information i cant really tell you anymore.adrian
Feb 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Draining
if you select drain spin and you hear the pump running then check all the hoses for blockage if you dont hear the pump running then make sure your door is locking
Jan 19, 2008 | Maytag Neptune Washer
My washer won't stop draing as it fills
Does the washer makes a full cycle properly and only problem is water's constinously draining ? If this is the phenomena, verify that the pipe discharged to the drain hose (the pipe that water going out from the machine)is at washer height up to one foot higher. Goog luck !
May 25, 2006 | GE WBB4500EWW Top Load Washer
Kenmore 22622 Top Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
