Question about Gateway DX4300-03 Desktop PC
I just bought a new Gateway DX4300 and it will not let me connect to my wireless network, or see any available networks.
    Problem Solver:
  • 18 Answers
You need the driver download it from the internet
Posted on Sep 04, 2010
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
I have a windows 8 gateway laptop(NE71B Series) and its seems as if my wifi switch is disable. Anyone with a bit of advice on how to resolve this problem would be very helpful.
Recently had a coworker bring me a Gateway NE71B laptop.
Complaint: No wireless even using a VZW 4GLTE hotspot.
Observations:
; All drivers and devices are functional with no errors or conflicts.
; Wireless adapter has power and is not in Airplane mode.
; No wireless networks are visible even though there are normally as many as 12 networks available within the area.
; Wired Ethernet adapter works without issues.
Solution:
Turns out the BIOS was v2.05. After updating the BIOS to v2.13, wireless connectivity is functional. All locally available wireless networks (SSIDs) are visible.
Notes of caution:
; A failed BIOS update will invalidate your warranty per Gateway chat support rep.
; Ensure you have a fully charged battery before updating the BIOS.
; Ensure your AC adapter is plugged in and functional prior to starting the BIOS updater.
Jan 22, 2013 | Computers & Internet
We bought a desktop emachine, and we already have wireless internet but we can't connect to desktop wireless ..why ?
The new machine's network settings need to have the GATEWAY ip address set to the ip address of the router which will be something like 192.168.0.1 depending on the router you're using. If you can't see any networks available make sure the wireless connection isn't disabled. Look at NETWORK CONNECTIONS, wireless connection and see that it doesn't say disabled. If it is simply right click and select ENABLE.
Feb 18, 2011 | E-Machines eMachines Desktop PC
I cannot get my laptop to connect to the internet either wirelessly or hard-wired. I have two other laptops, connected wirelessly, and a desktop connected via hardwire. It recognizes the router but says...
if you are trying through wireless, first unplug the wire from the laptop,
make sure that the wireless switch on your laptop is turned on.
click on start, control panel, network connections/network & internet/ Network and sharing center..
right click on wireless network connection Icon, if it says disable, it means it is enabled already.
then click on status..
from here the steps would differ from OS to OS
then click on Support tab (for XP)
check the address type, it should be "Assigned by DHCP"
and if you see the IP Address starts with 169., it is a bad IP and needs to disable the connection and enable it.
if the connection type is "Assigned Manually, right click on wireless network connection icon and click on properties and click Internet Protocol(TCP/IP) and click on properties, in this window, check the option "Obtain IP Address Automatically from DHCP"
click ok and OK ..
again right click on the wireless network connection icon and click on view available networks... click on your router name and click on connect..
now check the functionality.
if you are using windows 7 or vista,
click on status, click on details for the IP Address..
We see DHCP Enabled as YES or NO instead of "Adress type"in XP
if it says no, it means it is assigned manually. to change to DHCP , right click on Wireless Icon, select properties, click on IPV4 IP address and click properties, then select obtain automatic..
then try again..
hope this works,
Narendra Tirunahari
Feb 18, 2010 | Gateway 7330GZ Notebook
I need help connecting to the router
you just bought the new computer. I belive it must be having the wireless card. Go to the control panel and go to network connections. If you see wireless network conenction in the network connectin then you don't need to buy anything.
Is your router already set up and other computers are online using the router ?
in that case you don't need to run the CD. you just need to connect to the network ?
Click Here to know more about how to connect to the network
Nov 19, 2009 | NetGear WGR614 54Mbps Wireless Router...
Gateway 7510gx how do i get the wireless to work
Check out if the hardware switch is turned on. most of the times this works. IN case the hardware switch is on, go to start>settings>network connections and double click on the wireless connection icon. Ideally it should throw up a series of wireless networks available in the area.
Jul 09, 2009 | Gateway 7320GZ Notebook
Network key retreival
Is it possible that you never changed the default wireless key? If you didn't, the number in '[ ]' brackets printed on the bottom label is the wireless key.
If you've changed that from the default when setting up your wireless network, you'll most likely have to reset your router.
Of course, if you do a reset on your router, you will also have to re-enter your DSL account / password in the router
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Problems with wireless connection - gateway notebook
Might be several things, but perhaps start with checking for any driver updates that might be available.
Feb 11, 2009 | Gateway (802.11usb) Wireless Adapter
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Cannot connect
Assuming you are on Windows XP click on site below for router setup. http://support.gateway.com/s/NETWORK/7004809/7004809slWindowsXP.shtml The Nintendo 'Cloud' is just a network name so that when you are in a building that has supported wifi, you search for the network and use My Cloud as the password for connection on Nintendo DS. The settings you may require for the Nintendo Wii will probably be your routers IP address, Gateway and DNS address (just use same numbers). Apologies in advance if i'm incorrect as i have only setup a nintendo DS on my own wireless network and as Wii are not yet available i have no knowledge of it yet.
Nov 30, 2006 | Gateway Wireless-G WGR-200 Router...
Gateway DX4300-03 Desktop PC  Logo
314 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
