Question about Swisher 60" 13 Hp Trailmower #T1360h
Have a Swisher 44 rough cut trailmower, how do you change the belt?
3 Suggested Answers
  • 4 Answers
SOURCE: cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Posted on Jun 26, 2009
  • 11 Answers
SOURCE: I need replacement parts for my 60
try e-bay
Posted on May 05, 2010
What causes belt shredding on swisher pull behind mower, 44" cut, 11.5 hp
how old is your trail mower? have you checked the pulleys for the belt drive? possibly the pulleys are loose, or the shafts holding them are worn and wobbling causing a misalignment of the belt, in turn shredding the belt. also check the pulleys to make sure they are smooth, allowing the belt to move cleanly
Jul 18, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
How to replace belt
SWISHER 44 Finish Cut Trailmower Tension assembly belt bra Parts Model...
If you look at the diagram ( zoom in) part #94 , idler spring, is what puts tension on the belt.
Jun 07, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
Change belt
Changing the belt on the swisher 44' rough cut - mine is a model RTB134412v. You have to remove the belt guard (4 bolts) and then the 6 bolts holding the engine on to the deck. Lift (or tilt) the engine up and loop the 1/2"x50" belt (I got a husky replacement belt at tractor supply) through the wire belt guides and around the engine belt drive. Then loop the belt around the larger blade drive. It takes about 30 mins or so. Hope that helps.
Oct 24, 2013 | Swisher 44-Inch 12.5 HP Trailcutter...
What size belt for my swisher 44" pull behind
I just replaced the belt on my 44" Trailmower and since I had to get it up and running without waiting for new Swisher 4220 belt I found an ordinary V-belt 1/2"X72" whith overall with of 74" works OK
Jun 28, 2011 | Swisher 44 Iinch 11.5 Hp Trailmower...
What size belt fits swisher 44 inch cut mod. no.t 11544
Our manual says 74" part no. 4220. We just replaced one but can't figure out how to adjust the tension.
Aug 17, 2010 | Swisher 44 Iinch 11.5 Hp Trailmower...
What is the width of the drive v belt.
Hello. here is the link to a free downloadable owner manual and parts list http://www.swisherinc.com/customer_support.asp
This will answer your questions and much more. J
Jun 01, 2010 | Swisher Trailmower 44" Cutting Width, 11.5...
Swisher 60" 13 Hp Trailmower #T1360h Logo
213 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
