Question about George Foreman GR36-59A Indoor Grill
On the GB 36 Model: Is there some reason why the red light doesn't go out anymore and the grill gets increasingly hotter to the point that it is now burning the food?
  • domatax Sep 04, 2010
    Thank you, I shall persue that advice.
  • 4,323 Answers
Hi
this red light is indicating the failure of temperature sensor, the grill is not detecting high temperature and is not cutting the power off to the grill. To resolve the issue, turn off the power and unplug it. Let it cool down & remove the screws from the back of the grill, now check for the wiring and temperature sensor attached to the bottom grill. Check the connections on the sensor, replace if necessary. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 04, 2010
    Top Expert:
  • George Foreman Master
  • 79,123 Answers
The thermostat has failed, contact the manufacturer to see if u can buy the part, it is easy to chage, just ull the top apart.
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
My compass doesn't point north, what is the reason?
The reason why your compass doesn't point to the north anymore is because the compass has been exposed to articles with iron content, like the compass being placed next to a pair of scissors or a knife, microwaves, and high tension wires.
Sep 03, 2012 | Acr Electronics Camping, Backpacking &...
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
Can I convert a NG Vermont Castings BBQ to Propane. moving and new house has no NG available. Model SCS 5005.
Unfortunately, Peter, for safety reasons, VC grills are not approved to be converted from one gas type to another. Each grill is manufactured, tested and approved for it's specific gas type. Converting it from LP to Natural Gas places all the liability on you, if something should go wrong as a result of the conversion. Further, you would notice a significant change in the heating ability and the lower flame height, when set on high. The reason for this, is that LP Gas burns cleaner and hotter than Natural Gas in an outdoor environment.
I know you would be happy not having to refill the tank, but I think you would really disappointed in the performance of the grill, if converted to Natural Gas.
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Sep 15, 2011 | Weber Grilling
& Single Handle Shower Faucet : how to adjust to get hotter water...
First step remove handle and behind it there is a dial that looks like a gear. Mark where it is and remove it and put back in about a 1/4 to 1/8 turn counter clockwise to increase to hotter temp.
These faucets are equiped with anti scald setting's to protect the public and preset for this reason.
May 17, 2010 | Delta & Single Handle Shower Faucet
One side of the grill gets hotter than the other.
Is this grill new? How many burners are on this grill? Typically if there is a pressure problem, the farthest burner from the regulator suffers. Looking at the photo of the grill, the tank and regulator are on the right, which would make the left side burner weaker. The flames can be even all around each burner, but if the burner on the right has slightly taller flames than on the left, even increasing the pressure won't "even" it out, it would just make both bigger. It could be just the nature of the beast. If it was feasible and the left and right burner were identical, it would be interesting to see if switching the burners would make any difference. Check to make sure each burner's air shutter adjustment is the same and adjust each for the bluest flame possible. Look for spiderwebs, bugs, or rust debris and blow out with air compressor, if possible. Let us know if you need more assistance. Good luck!
May 18, 2010 | Weber Genesis Silver B Grill
I want to increase the storage capacity my Hard disk.
hi,
You can use SATA hard disk.
you said you already have 40gb. so, your pentium 4 mother board can work with full performance with upto 80 gb.
My suggestion for you is to get another 40 gb and install it ,so it makes 80 gb as total.
Other option is , There are external hard disks available for reasonable cost. you can go for it.
Your RAM is ok too.
Hope my info helps you.
Bye.
Sep 25, 2008 | Computers & Internet
Tv wont turn
replace the AC fuse, a GMA 6.3 amp fuse. I have seen many of these sets where the AC fuse opens for no apparent reason.
Jun 18, 2007 | Panasonic CT-36HL43 36" TV
George Foreman GR36-59A Indoor Grill Logo
61 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
