Question about Panasonic Palmcorder PV-GS120 Mini DV Digital Camcorder
I accidentally dropped the camcorder. Now I get a blank screen in record mode, in both the LCD screen and the viewfinder. The playback mode works perfectly. Any advice would be most appreciated. Thanks.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 04, 2010
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
DCR-TRV22 Blank LCD & Viewfinder
I would try removing the battery and plugging it into the mains if this works you know it is your battery and you need a replacement.
Dec 05, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
Apr 22, 2017 | Sony Handycam DCR-HC21 Mini DV Digital...
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Camcorder LCD screen only operates up to 30 degrees from camera
open the unit. find the flat flexible connector to the LCD and then look at each end to verify if fully inserted into its mating connector.
May 30, 2007 | Panasonic NV-GS15 Mini DV Digital...
LCD is blank
Yes but needs to go to service .The strip connector between the lcd and main pcb board is faulty and needs to be replaced.
May 22, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Panasonic Palmcorder PV-GS120 Mini DV Digital Camcorder Logo
74 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
