Question about Frigidaire FAH125N2T Air Conditioner
Frigidaire FAH125N2T Air Conditioner is 6 years and still runs very smooth but no longer blows cold air. What could be the problem?
    New Friend:
  • 50 Answers
Check the freon..check if the compressor is still running.
Posted on Sep 04, 2010
  • Frigidaire Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Why is my air conditioner not blowing cold air
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FAC107P1A, comes on with the compressor running, but the air is not cold. First, check to see that the temperature sensing element, located behind air filter, is not touching a cold coil. If it is, straighten the element away from the coil. Secondly, try resetting to a lower temperature. Lastly, the compressor may have shut-off by changing modes. Wait approximately 3 minutes and listen for compressor to restart when set in the COOL mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire FAC107P1A Wall/Window Air...
Why isn't it blowing cold air and is dry inside, no water to drain out?
I understand that your Frigidaire air conditioner, model# FAC124, is not blowing cold air and there is no water draining out. First, try setting the temperature to a lower temperature. Secondly, make sure the compressor did not shut off by switching modes. Make sure it is on cool and wait approximately 3 minutes and listen for the compressor to restart. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire FAC124 wall/Window Air...
Air Conditioner not blowing cold air . I cleaned the filter. What is wrong?
cleck the coils if they are dirty the system wont cool is the compressor running when the coil is dirty it increases the head pressusre or lower the suction pressure does it freeze up
Sep 13, 2010 | Frigidaire FAX052P7 Compact Room Air...
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
My air conditioner is not blowing cold air. What can be done ?
look for a couple of things ... if the compressor just buzzes intermittantly but doesnt run then suspect its starting capacitor (small rounded metalic rectangle) .. that has wires connecting it to the compressor .. .. if you can hear the compressor start but it still doesnt cool then you likely need refrigerant added .. thats done by adding a saddle valve service port ... any leaks have to be repaired ..
Jul 25, 2010 | Haier Mechanical Air Conditioner HWF05XC7
When i turn a/c on. the motor barely spins. it wont even spin fast enough for the thermostat to kick in.
mcdevito75 here, Sounds like the fan motor is shot, Check with your local a/c repair shop or replace the unit.
Jun 21, 2010 | Frigidaire FAH125N2T Air Conditioner
Fan works but not blowing cold air
Is the compressor running? If it is then you are probably low on refrigerant and needs to be leak checked and recharged.
Jul 16, 2009 | Frigidaire FAC125P1A Window Air...
The compressor is running but not cooling.
Try the following to begin operating the air conditioner: 1. Plug in the air conditioner. (To prevent electrical hazards, do not use an extension cord or an adapter plug.) 2. Set the exhaust vent to the CLOSED position. 3. Press “On/Off” button to turn unit on. 5. Press Mode “COOL” 6. Press “TEMP/TIME” up or down V to the desired set temperature. Review the “Air Conditioner Features” section for other settings
Jul 10, 2008 | Frigidaire FAS185N2 Air Conditioner
Frigidaire FAH125N2T Air Conditioner Logo
174 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
