Question about HTC P3300 Smartphone
The phone is not switching on
The phone got switched off suddenly n its not gettin charged....ders no charging light indication.its a htc p3400 phone
    An expert whose answer gotĀ voted for 100 times.
  • 143 Answers
New battery
charge while off
led goes off when done
Posted on Mar 15, 2010
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
I have htc p3400. i replaced the battery but my phone is not turning on. no indication that the battery is charging. (no orange light). when i switch on the charger, only once the light (red & green...
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jun 17, 2011 | Cell Phones
Phone not switching on
where you plug the charger in on your phone, if you look into it you will be able to see the contacts for it to charge.
on the inner OUTER wall of it ther is 2 pins, use a needle to pull them out a little bit but be carefull not to sanp them.
just so they stick out a little bit, if you do this and the charger dont go in then dont bloody force it in otherwise ya
only when the orange light is on its charging, if you accour a flashing orange light do it again.
this should sort your charge problem.
however you will eventuall need to do it again.
Aug 20, 2009 | HTC P3300 Smartphone
I have aHTC P3400 Pocket PC . Now the phone in off position . I Cannot switch on it. A red LED in top is seem.
hi when a red led is in view i would suggest fully charge as led should show green on power up
Jul 28, 2009 | HTC Touch Cellular Phone
Htc p3400i windows mobile....Battery Charging Problam!
I am also facing the same problem with my O2 XDA mini. It seems to be the problem with the battery/charger. Are you using genuine battery/chargers that came with the phone? I am using a local battery so assume that it has to do something with the battery itself.
May 12, 2009 | Cell Phones
Nokian73 not switching on!!!
i need the nokia n73 software download .my email address:
Apr 24, 2009 | Nokia N73 Cellular Phone
HTC S710 Smartphone not switching on
The battery is flat.
If the battery is very flat sometimes the phone will not start charging or turn on even when a power cable is connected.
This worked for me:
- Remove battery
- Insert power cable/usb cable
- Orange charge light should start flashing
- Re-insert battery
- Leave phone charge for a couple of hours
- Turn on
Feb 03, 2009 | HTC S710 Smartphone
Htc 8125
there will be some problem in the charger or in the charging port of your cell ..
just have a check with the charger first with another mobile if needed replace it ..
if you still persist the same problem then there may be some problem in the charging port of your cell ..
the charging port may be is in loose contact ie it might not be touching the motherboard of your cell correctly just have a check by opening the cell if you are good at opening if needed replace the charging port ...
rate my solution
Sep 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC P3300 Smartphone Logo
120 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
