Question about Jenn-Air Kitchen Ranges
How do you use the clean cycle on a jenn air model S260
  • Jenn-Air Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Sep 04, 2010
Sanyo sc-s260 user manual
I want to clean my vacum cleaner, How i can open my sanyo vacum cleaner model: sc-s260
Dec 26, 2013 | Metropolitan Vacuum Cleaner Vacuums
Self cleaning ovens
Perhaps it hasn't cooled down enough; or you may have to run the self-cleaning cycle again. The oven has to reach a certain temperature before it starts to turn the residue to ash.You may have interrupted its cycle.
It then has to cool off sufficiently to safely open the door.
Dec 22, 2012 | Jenn-Air Kitchen Ranges
MY JENN-AIR MODEL #WW2460B WALL OVEN DOES NOT DISPLAY THE CLOCK/TIMER. IT STOPPED WORKING DURING A SELF CLEAN CYCLE. IS THERE A WAY I CAN ORDER THE PART TO REPLACE IT MYSELF AND ARE THERE WIRING SKEMATICS...
There is a high limit thermostat that will cut all the power to the upper oven elements. Their is a wiring diagram in this link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-WW2460B/1266/0125300?pathTaken=&prst=0&shdMod=WW2460B
when clicking on it,it will say not avaliable. A trick i have found is to open that link and then using your computer tools select the maximum zoom i use IE set to 400% and its pretty ledegable.
Gene
Aug 11, 2011 | Jenn-Air Ovens
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
How to turn off self clean oven Jenn air slide in older model after it is done cleaning
the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
Oct 08, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Oven door will not unlock.
You will not be able to open the door if you turn off temp gage. Return the temp gage only to clean and door should open.
Dec 13, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
70 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
