Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Brushes no longer spin. trying to clean excess hair from area but can not figure out to change belt if that is the problem.
    New Friend:
  • 50 Answers
Check the belt if it is still connected to the brush
Posted on Sep 04, 2010
My brush is not turning and the belt is on the motor. I think the belt motor may be bad due to excessive dog hair. How do I get to the motor?
I had one melt the plastic around the bearings on the brush. you might try taking out the brush first, getting to the motor you'll have to take it completely apart.
Feb 27, 2015 | Bissell Lift-Off(R) Revolution(R) Turbo...
Why wont the brushes spin?
Most likely, the belt is broken. I'll bet the roller is covered with hair, thread, string. If brush roller is not routinely cleaned, string, hair becomes rapped around it and makes it more difficult for the belt to turn it. Eventually, the increase in friction and heat weakens the belt and the belt either breaks or stretches out. Try cleaning the rollers and replacing the belt.
Jul 29, 2014 | Miele Vacuums
I have a Dyson DC07. The roller wasn't spinning so I cleaned the brush of hair and fibers. That SEEMED to do the trick. But while vacuuming I noticed again that the roller brush was not spinning AGAIN. The...
You may need new belts. Belts lose elasticity from being stretched. The clutch must be removed and disassembled to change the belts. It's easier to replace the clutch. The belts will be tight and It's difficult without a special tool. While you have the brushroll out pull the shaft out of the center and clean hair and debris from it or replace brushroll if worn or frayed.
Dec 22, 2017 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Change Belt
Hair and debris works it's way under the end caps of the brush roll causing a restriction. If you can't clean the debris out and get the brush roll spinning greenly you may need to replace the brush roll.
Mar 25, 2014 | Vacuums
Brush stops spinning
the first thing to do is pull the brush and make sure the end caps spin freely. Clean hair and debris from under end caps if they can be removed. Install a new belt if it's been longer than 3 months since it has been replaced. Belts lose elasticity quickly even if you do not use the vacuum,
Jan 15, 2014 | Vacuums
Turbo tool used only once or twice, already brush moves so slowly it stops when I try to use. Brush can actually be stopped by hand. Manual says nothing at all about the brush ie. HOW to take apart to see...
It takes a lot of suction to spin the brush. First make sure the suction is good. Make sure the bag and/ or filters are clean. Replace if necessary. Most turbo tools can be opened up to clean. Most have a lever that allows you to open it up to clean hair, dust, etc from the fan and fan shaft and other areas inside the tool. The tools pick up a lot of hair and debris and some will wrap around the moving parts building pup to the point the brush will not spin fast enough. The same thing can happen to the brush roll on your vacuum so be sure to clean it too and replace the belt at least twice per year.
Oct 31, 2013 | Eureka Vacuums
Brush not spinning
1. Make sure the belt is in contact with the shaft. 2. Remove the roller and clean the brushes AND the area that seats into the vacuum. If there is too much hair, string, etc. the brush may not roll. chances are the belt is probably not making contact. If it was you would smell rubber burning if the brush wasn't turning.
Mar 03, 2013 | Kirby Vacuums
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
79 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
