Question about LG Heating & Cooling
THE COMPRESSOR IS CYCLING EVERY FEW SECONDS IT HAS NOT DONE THAT BEFORE LIKE HMMMMM HMMMM HMMMM
  • 24 Answers
Sounds as though the compressor is trying to start, and then shuts off, then tries again. If this is the case...
Usually this results when the capacitor has gone bad and the compressor is unable to start or break free to run.
Basically a capacitor gives the compressor a "Bump" to allow the pistons to break-away from the stopped position. Once the compressor is operational, the capacitor circuit is dropped and the compressor functions as expected. When the capacitor goes bad, the pistons cannot move and the compressor over-amps and the internal, or external OL (overload) opens due to high amp draw. When the OL cools down it allows the compressor to try to start again. But as it cannot it will make a loud humming noise as if it were locked up.
Which brings me to my second solution.... the compressor is locked up mechanically. And the pistons have siezed or welded themselves stationary. If this is the case, and the capacitor checks out good, then the compressor will need to be replaced.
Posted on Sep 04, 2010
While travelling on I-10 west at 80 miles on cruise the truck stalled, what could have caused this
Hmmmmm.
- Out of gas?
- Fuel pump failure?
Hmmmm
- Electrical? Not as likely, but possible.
Jul 13, 2015 | 2004 Chevrolet Silverado SS
T- 49f freezer short cycle on and off
either a t-stat issue or if it does not run for more than a few seconds, your compressor is done for.
Apr 10, 2014 | Freezers
Fridge cycles on and off every few seconds
sounds like the compressor can't start. could be the compressor itself, or the capacitor that kicks it on
Nov 13, 2013 | Maytag Refrigerators
Replaced all A/C major components (compressor, filter-drier accumulator, and orifice tube) except condenser due to a seized compressor and failed clutch bearing. Flushed system and appeared to have no...
It sounds like you've done just about everything except to check if there is a bad or intermittent wire causing this or perhaps your low-pressure safety cutout switch is possible going bad causing the compressor to kick on and off?
Nov 01, 2013 | Lincoln Town Car Cars & Trucks
Forester ac compressor cycles every few seconds but pressure on lp side shows high in gauge
Is it possible you hooked up to the factory service port on the high side instead of the low side port ?
Can you hook up a set of gauges to both high and low ports ?
Jul 27, 2012 | Cars & Trucks
Hotpoint future freezer red light stays on and motor makes buzz noise every few mins but only for about two seconds.
Hi and welcome to FixYa, I am Kelly. Your hearing the compressor Thermal overload cycle every few minutes for no more than 45 seconds. The compressor is not starting at all or it is not cycling from the start winding to the run winding so the KliXon thermal overload is tripping. That switching of windings is done by the PTC relay mounted on the side of the compressor. The Compresor part number is EMY32CLC. PTC relays can be found here:
http://www.europart.co.uk/s.nl/sc.2/category.690082/.f You will have to match your relay to the image.
I would recommend using the phone locally to purchase the relay AFTER performing the following.
POWER OFF / Unplugged WAIT 30 minutes for the compressor to cool and the coolant pressures to stabilize. After 30 minutes plug in the unit and see if the compressor starts.
IF after 30 minutes the compressor does not restart....
1. Read the pins of the compressor to the case of the compressor. No grounds allowed.
2. Read pin 1 to pin 2 (on 2 pin compressor) you should read resistance.
3. If you have a 3 pin compressor only 2 of the 3 pins will read to each other at any given time. One for start winding and one for run winding with 3rd pin being common.
A locked compressor rotor/armature will also cause the compressor not to start. A locked rotor requires compressor replacement. (Fingers crossed lets hope that the rotor is not locked!)
Hopefully your unit will restart. A momentary loss of power will cause a compressor to hot cycle and not restart. All it takes is about a 8 second power loss to put the compressor into this no start frenzy. Do the 30 min no power thing and see what happens. (maybe save your self lots of money.)
Thanks for choosing FixYa,
Kelly
Dec 05, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
A/c doesn't work, tries to cycle for a few seconds 1998 Chevy Tah
If the freon is full and at correct pressure, then have the switch located on a/c compressor tested. Had the same problem and it was the switch on compressor.
Jul 03, 2010 | 1998 Chevrolet Tahoe
Motor cycles on /off every few seconds
Bad relay on compressor or bad compressor.
Apr 07, 2010 | Engel 43 Qt.Portable Freezer.
Compressor runs only a few seconds then clicks off
The compressor is going bad, check your owners manual for warranty information or look here http://b2b.frigidaire.com/support/manuals.asp if you cant find the manual. Some units have up to 7 years on the sealed system (the compressor, cooling coils, and hot coils).
Jan 30, 2010 | Refrigerators
Heating & Cooling Logo
139 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
