Question about Saniflo & Saniplus& Macerator Pump
Motor will not shut off unless disconnected from the electrical outlet. Unit is connected to toilet - tub & sink. Unit model is: Sanivite EN 12050-2 FF0V30 120v 60Hz 5,7A 4/10 HP age 4 yrs.
    Scholar:
  • Saniflo Expert
  • 115 Answers
The Sanivite is a gray water pump, does not have a connection for a toilet. It has a pressure chamber inside the pump casing and a float switch at the bottom of pressure chamber. You will find a black rubber membrane which water pressure pushes up on the membrane and turns the unit on and off. It could be that something is stuck at the bottom of the membrane keeping it in the on position the whole time or the membrane might be warped. Also the micro switch may be stuck on the on position. Pry open the lid with a flat head screwdriver and inspect the pressure chamber.
Posted on Sep 15, 2010
Can you tie into a common dscharge pipe when plumbing a sanivite and saniplus?
I think it can be done , but it may be against the local code for your area. The obvious concern is back up of sewage in the sink, and washing machine.
Feb 01, 2013 | Home
Saniflow problem
My Sanivite has packed up again (humming no pumping) for the third time, (7years old!) always the capacitor, don't buy from Sanivite get off ebay half the price.
May 29, 2012 | Saniflo & Saniplus& Macerator Pump
Sanivite smelling first thing in the morning
The unit has an 1 1/2" vent connection on top of the unit which must be vented to the open air (outside of the house) as per plumbing codes. Check for any loose connections or maybe the connection into the main sewer line may be leaking causing it to smell.
Sep 01, 2010 | Saniflo & Saniplus& Macerator Pump
Do the saniflow toilet need to be plumbed in to mains waste? I have a patient who needs a toilet located outside the house that needs to be trouble free
Hi and welcome to FixYa, I am Kelly.
In short yes it will need plumbed with a smaller drain line to the home waste drain.
The unit uses a fast-rotating blade to reduce waste and toilet paper in the flush water, which is immediately and entirely released under pressure through "small-diameter piping" to the sewer or septic tank. No special maintenance is needed and the pump is sealed for life. This simple and cost-effective alternative to conventional plumbing is ideal for basement renovations and other home-improvement projects. Properly sized, a Saniflo macerating system can handle all the fixtures in a bathroom, including the sink, shower, tub and toilet & endash; even on a septic system. What's more, these fixtures will work up to 12 feet below and as far as 150 feet away from a septic tank or sewer line.
Go to this page and download the manual for the installation instructions:
http://www.saniflo.com/Downloads.aspx
These are all the installation downloads available on that page:
Installation Instructions:
SANIBEST SANIGRIND SANIPLUS SANICOMPACT SANIPACK SANIALARM SANISHOWER SANISWIFT SANIVITE SANICUBIC Classic SANISTAR SANITOP
Thanks for using FixYa,
Kelly
Jun 01, 2010 | Home
Fridgidair Dishwasher takes long time to run
ok with the soap prime the sink before you start it and clean the dish washer.take a table sppon full of tang put it the dispencer and run the unit this will clean the unit
Apr 25, 2010 | Dishwashers
Both toilets and bath tubs are clogged.PLEASE help . its a crane but i dnt knw the model.
You have a main drain clog. The sinks are clogged too (run water and you will see it come up the tub). Is this a one floor house? Basement? You probably should call a plumber unless you are willing to take on the task of snaking it yourself. Sounds like you may have a house on a slab? (no basement)?
Dec 27, 2009 | Crane Plumbing 3755 Toilet-To-Go Metro...
I have a 3 year old Sanivite 3 macerator that has stopped pumping. It is used under the kitchen sink for removing water and soft food waste. Yesterday I removed the unit and cleaned the inside which was...
if the unit is properly clean and you have checked the fuse - then i suggest it is the microswitch that needs replacing. these tend to go (break) within 5 years on the sanivite 3 models. If not the swich then it could be the capacitor (try this first - although as the swich is located next to the capacitor you can test this for operation at the same time). if none of this works then its time for a new unit.
Nov 09, 2009 | Saniflo & Saniplus& Macerator Pump
I have a saniflo system and need to know how to unblock it
check the fuse has not gone or the trip for the electrics before proceeding as no power = no saniflo, assuming this is ok -
1. get old rags/papers and some rubber gloves (marigold type), plastic beaker and a bucket.
2. get a pozi and a flat screwdriver
3. isolate electric supply to saniflo
4. ensure loo cannot be flushed (tape handle)
5. place cloths and papers around pan
6. bail water from pan into bucket (as low as poss) with beaker
7. slacken screw to pipe on top of saniflo (outlet)
8. get bucket (now emptied) disconnect pipe and prepare to catch liquid from pipe, especially if pipe goes up the wall.
9. slip connector off pan, depending on model there may also be a connection from a sink / shower / bath to disconnect.
10 attempt to withdraw saniflo from behind pan - if this is not possible you will have to remove the pan.
11. remove top from saniflo (screws around lid)
12 when the top has been removed you will see a basket inside, if the blockage is from a female article (of the cotton wool nature) this will be jamming the motor and pump, remove any problems (sometimes a loo fresh thingy) take care as there are masserator blades at the bottom of the basket.
13 if the basket is clear and you can see the blades it is a unit failure - it is often cheaper to buy a new one than pay for a service engineer, check first.
14 if you can remove the blockage then do so - re-instatement is the reverse of removal.
If in any doubt seek professional advice, if you get stuck seek professional advice, do not reconect electrics unless you are sure everything went ok, do not reconnect electrics sitting on damp floor, best leave everything to dry out before reconnecting and trying it out
Oct 21, 2009 | Saniflo SaniPlus-Elongated SaniPlus...
Whirlpool LTG6234DQ Stopped Now Won't do anything
a sink stopper will not damage your unit its to big,,it cant get though your wash basket...check your outlet,,or use another out rated 15 amps or more..
Nov 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Saniflo & Saniplus& Macerator Pump  Logo
993 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
