Question about Brother MFC-5440CN All-In-One InkJet Printer
My printer not working
My MFC 5440CN keeps on showing on the display unit ' no cartridge, open scanner cover and reinstall ink cartridge. i have bought some new ink cartridges up until this new lot i was just refilling the old ones. please help me as my essays are due in for university and i am getting desperate.
thanks soraya
  • 3 Answers
Beside of the cartridge there is an optocoupler. Clean it or replace it
Posted on May 23, 2008
It sounds like a manufactuer defect
Posted on May 11, 2008
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Printer keeps saying no catriage after I change the cyan color.
Its posible there is another ink cartridge that is now empty. Open the cover for the inks and see what it says on the display. If it asks for another ink replace the one it asks for. If its still asking for CYAn there may be something wron gwith the sensor for the cyan
May 02, 2010 | Brother MFC-5440CN All-In-One InkJet...
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 06, 2009 | Dell A940 All-In-One InkJet Printer
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
My A940 All-in-One shows a Cartridge error 50C and also shows that the colour cartridge is missing when it is not can you please help tried looking through manual but cannot find what a 50C error is please...
Hi there Error 50c
All the best of luck
color cartridge.
Jun 17, 2009 | Dell A940 All-In-One InkJet Printer
I keep getting the error message that it "unable to init "
reinstall cartridge and follow instructions precisely because if you don't it won't recognize the cartridge
Dec 25, 2008 | Brother MFC-5440CN All-In-One InkJet...
Keeps telling me that there is an empty cartridge
see and search here: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc620cn_us
Sep 17, 2007 | Brother MFC-620CN multifunction Color...
Brother MFC-5440CN All-In-One InkJet Printer Logo
126 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
