Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
I have water leaking inside the heater above the burners on the left side. where is it most likely coming from and where can i have it fixed
  • 990 Answers
This is most likly your heat exchanger and you will probally need a new one. It will be expensive and you will probally have issues with some other components. This is almost always caused by chemical damage. If your heater is very old it is probally time for a new heater.
Sorry for the bad news.
Posted on Sep 04, 2010
    Problem Solver:
  • 3 Answers
I have two LT/LX units - one I use and one I keep just for parts. In taking them apart, I can see in the header gaskets where the water escaped out on both of mine. Looks like the gasket is designed too thin. You may very well need a new heat exchanger, (very costly) but you might try a $20 gasket replacement first. Part number is R327500 and fits the front or rear header. $25 bucks for each header with shipping from a variety of places on the internet.
Posted on Dec 27, 2010
2004 territory has a water leak above the transmission Its coming from a small house from inside the car an the heater vents have also leaked water into the on the floor on the drivers side?
I would say clean out the hose first. Should any way, they do clog up. But you may have a bad heater core. Costly. You can bypass it. Find the 2 hose going into the fire wall and connect them together, till you can get it fixed, winter time is cold.
Jun 28, 2016 | Cars & Trucks
HOW CAN YOU TELL IF THE PILOT LIGHT IT LIT ON A H200 ABOVE GROUND HEATER
To see if the pilot itself is lit first remove the front cover. Near the bottom left hand side of the cabinet with the cover removed, look just above the burners you will see an oval hole punched out of the front panel. You can look inside the small opening to see if the pilot is burning. You may need to look on a bit of an angle to the left side of the burners and your should see it
May 24, 2014 | Hayward 250kbtu Ng Pool Heater - Inground
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood 6 gallon water heater with electronic ignition that works well, but after running a while my vapor sensor in the RV goes off. By process of elimination we have determined it is the water...
Obviously something ( propane or carbon monoxide ) is leaking inside the unit either while water heater is running or after. I hope I don't need to warn you how dangerous this can be, and that you should have it checked by a qualified technician A.S.A.P. , and propane should be shut off until such.
With that said, 3 things come to mind that should be inspected or considered. Look at where propane line comes through housing of water heater and attaches to gas valve. There should be a rubber grommet in the hole and it should be air tight so as not to allow any fumes or gas to enter back inside trailer. If it's not air tight, use a silicone type sealant and seal it good at that location. Another thing I would look for is any window or opening above water heater that may be allowing fumes or gas to enter inside trailer. Next, I would take a spray bottle, fill it with water and squirt some liquid dish soap in and mix it to test for leaks around all fittings at water heater, and especially spray orifice where gas comes out of valve and enters burner tube, when heater is off, to see if any bubbles form at end of that orifice, which would indicate a leaking gas valve. Again, I urge you to have it checked by an experienced technician for the safety of yourself as well as your family and friends.
Jun 23, 2011 | RTO Atwood Water Heater - 6 Gal LP
Rheem water heater model #82V661 serial # RH0106D11663 leaking water at lower panel. Water is coming from above wiring and control panel. Is this fixable or need to be replaced? Mfg date is 01/2006
You have 240volt electric water heater
Check both elements for leaking.
Check top of tank for leaking pipes.
If water heater is leaking from side of tank, then tank is rusted out and could rupture.
This tank must be replaced.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
My friend welded his tank to get more life out of tank, but he assumed the risk.
Hot water heaters are under pressure from heated water which expands.
If tank ruptures, water will flood out of tank and water will run until shut-off is turned OFF.
This causes major damage inside home.
Protect yourself first, and then let's talk more.
1) Turn off water at shut off located on cold water line above tank.
2) Turn off power to water heater:
Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
Electric heater, turn off circuit breaker.
3) Open tub spout on hot side and let run a bit to relieve pressure.
4) Now your property is safe.
You can limp along with failed heater if leak is slow.
Turn heater ON when you need hot water.
Typical Gas heater makes 41 gallons hot water per hour.
Typical Electric heater makes 21 gallons hot water.
Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
http://waterheatertimer.org/images/Water-heater-reference-guide-2.jpg
If you are going to install heater yourself:
Look at label on side of old tank to identify size and particulars.
I buy ordinary heaters from Lowes and Home Depot and always buy scratch-n-dent models when possible, because superficial damage to outer tank does not lower lifespan of heaters I have installed.
Buy same size heater if it worked fine before.
Buy new flexible water connectors.
Set water heater in drip pan.
Offer 10% less than price shown. Make them deal with you. Shop Ace hardware, Lowes, Home Depot. Kick the tires since you have a bit of time.
I know you have electric heater, but many folks read these answers, so I include info on gas too.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit if you encounter 1 repair. Electric tankless heaters require larger electric service box. Gas tankless require larger gas line (larger gas line, more gas consumption, bigger bill unless you cut consumption)
2) How to install gas heater:
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
3) How to install electric heater:
Read link above because many of same steps apply to electric.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in circle so it fits inside dip pan. Wrap entire electric heater with insulation blanket, except don't cover TP valve.
4) Connect bare copper jumper wire between hot and cold pipes to prevent stray current corrosion which will shorten life of tank. Make sure cold water line is grounded.
Also read:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
Jan 07, 2011 | Rheem Water Heaters
My reliance sta-kleen 502 is leaking. The water is dripping on top of the pilot light, extinguishing the flame . Please advise me with step by step instructions to diagnose and attempt fix this myself....
If you have a leaking water heater there is a serious problem.
http://waterheatertimer.org/Water-heater-leaking.html
Page shows how to limp along on a leaking water heater if your water heater needs replacement.
One of three things is causing the water:
1) Loose water connection on top of tank that is dripping down inside tank >> check pipes on top of tank.
2) The vent is clogged or not working correctly causing condensation inside flue pipe.
Condensation water is dripping back down inside tank.
Problem means possible CO poisoning if gas is not venting.
Look at vent pipe to see if joints are corroded.
Use long fireplace match > light match and put into draft hood at top of tank and see if smoke goes up.
Put hand at draft hood opening when water heater turns on to see if vent gas enters home.
Do same test when furnace turns on to see if furnace vent is pushing back into water heater.
Does water heater vent inside same pipe as furnace? You may need to set up separate vent for water heater if furnace gasses are pushing back into home.
Check furnace vent for obstructions.
Look at vent stack top of home to see if hood is in place.
Check if bird nest is built inside warm vent pipe.
Improper flue is top priority for getting fixed so vent gasses properly escape home.
You may have to call a plumber.
Professional plumbing forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Your water heater is rusted out.
A rusted tank has to be replaced.
It cannot be repaired.
However, before replacing tank, you do not want a tank failure where tank ruptures and water runs inside home until water is shut off.
This will cause major damage.
Protect yourself first.
Turn off water valve above tank.
Move gas knob to 'pilot' so burner is not heating water.
Open tub spout on hot side to relieve pressure on tank so it will not rupture.
Now you're protected.
Link above shows how to limp along on failed tank until you can replace heater.
You need a new gas water heater from Lowes or Home Depot
Look at label on side of you tank for gallons and btu's of your water heater.
Measure height to flue pipe so you get same height water heater, so pipes don't have to be changed.
You need a pipe wrench and teflon tape which will be wrapped on each pipe thread when pipes are reassembled.
Step1) Drain water heater using valve at bottom of tank.
http://waterheatertimer.org/Water-heater-will-not-drain.html
2) Turn off gas valve going into heater.
When gas valve is perpendicular to gas line, then gas is off.
Dissemble gas line to water heater.
3) Disconnect flue pipe and support flue pipe with wire so it doesn't not fall down. Flue pipe joints should be held together at each joint with 3 screws.
4) Turn off water. Shut off valve is on COLD side.
Disconnect water pipes.
5) Move old water heater out of way.
6) Set new water heater in place. Put water heater in drip pan.
7) Connect water pipes >> cold goes to side marked cold.
Hot to hot.
Buy new flexible water connector pipes at home center for easy installation of water pipes.
8) Connect gas line exactly as it was connected before.
Home center sells flexible gas line connector for easy installation of gas line.
To test for gas leak after installation, mix liquid soap with water and put around gas line joints to see if there are bubbles.
Natural gas has less pressure than water lines, so gas pipes are easy to seal with ordinary wrench.
9) install TP pipe that runs to floor. Use old one off old heater.
10) Fill tank completely with water until water is coming out of tub spout.
11) Turn on gas, and light pilot as shown in manual.
New gas heater sometimes have small water leak when first fired up, so ignore a bit of water.
12) Save water heater manual like it is gold, and read everything in manual.
Dec 18, 2010 | Water Heaters
Leeking water from bottom
I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
Also run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
Nov 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The burners on the left side of my burner tray do not come on? Getting out the burner tray seems difficult. What should I do?
Has water from rain or sprinklers gotten on the heater? Sounds like one of the following:
  1. Plugged burner orifices
  2. Plugged burners
  3. Low gas pressure
  4. Bad gas valve
  5. Poor venting
Your best bet is to remove the burner tray. It really isn't that difficult. Follow the owners manual. If you do this yourself, be sure to leak test all gas fittings.
Jun 26, 2010 | Raypak BURNER TRAY W/VALVE NAT 335
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
336 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
