Question about Sharp Wizard OZ-730
I have a Sharp Wizzard OZ-730 that I am having a problem with.....I have attempted to do a soft reset. No Go.......A messages then comes up that says the "memory in the organizer is not initialized or it is impaired".......A second message then comes-up that says...."Do you really want to initialize the organizers memory?"...This will delete all of the data in the Wizzard......The Sharp manual even cautions against doing this......Do you have any ideas how to troubleshoot???? Please advice......Thanks........
  • 2 more comments
  • ejdelligatti Sep 04, 2010
    Based on the information that is in the Sharp Manual I already know this........As I said in my original question....Is there a "work-arround" solution that I can use without loosing the data????? Please advice.......Thanks......
    Howdy....Thanks for the "trouble shoot checklist" Unfortunately I'm still getting the same "errors".........Is there another solution or work-around that I can recover the data???? I never have had a problem with the Wizzard OZ-730.....This is the first time something "major" has come up.......Please advise..........Thanks.......
    Taran....Thanks for the "cross-check"...That's what I was I was afraid of....I really appreciate your help.....Have a Good Weekend!!!!!!!!!
    Yes...Thank You!!!!!!
  • 10,515 Answers
# Initialize means to start over from scratch.
# The main memory is too jumbled for it to continue.
# The micro controller does not see any valid data so it wants to erase everything.
Check to see that the CARD LOCK switch is LOCKED and not in the
RELEASE position. You may have accidentally left it unlocked after
removing an IC card.
Check that the battery replacement switch on the back of the unit is in
the “NORMAL OPERATION” position. If the switch is in the “REPLACE
BATTERIES” position, the unit cannot be turned on.
Check or replace the operating batteries, even if you have just replaced
the batteries. It is possible that the batteries were not fresh when you
purchased them.
Press the RESET switch. If the unit has been dropped, for example, it
may have to be reset. This will not delete your data. If for any reason
data is missing after resetting the unit, it was lost before you pressed
the RESET switch. The RESET switch simply re-starts the unit.
* Do not reset the unit while holding down the ON button.
* If the procedures above do not work, the memory will have to be erased and you will have to revert to the last time the data was backed up.
Now,
You would ask :-
Why would the the organizer tell me to press the ON button while touching and releasing the RESET button if that was going to make me lose all my data?
Solution to the above Question :-
# Think of it as a damaged aircraft in flight --- you have to dump the extra fuel in the wing tanks to land safely.
# You can't save the fuel for later.
# There is no other choice if you want to save the machine for another day.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 04, 2010
  • taran_2005
    taran_2005 Sep 04, 2010
    Thanks for your response!!
    If the above solution would not work, unfortunately you need to contact the manufacturer to send the unit for repair.I wish i had a better solution.
    Hope i helped you.
    President:
  • 2,185 Answers
Hello there,
This means that your memory storage needs to be reformatted. And yes, this will wipe out everything that is personally stored on your OZ-730.
How did you perform a reset? You should hold down the Start key, push the RESET button on the bottom of the Organizer using paper clip. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
Choose YES. After the initialization, Welcome message will appear.
Please let me know if you need further assistance.
Is there an online manual for this device?
Here is a link to the download of the manual online.
http://www.retrevo.com/support/Sharp-OZ-730PC-PDAs-and-Handhelds-manual/id/281bh528/t/2/
Hope it was helpful?
Feb 26, 2011 | Sharp Wizard OZ-730
Looking for software for OZ-730. Found that www.mywizard.com is no longer an accessible site.
CALL thewizardshop.net 803-736-4382 they have software and sharp organizers.The wizardshop can help you with ALL your Sharp Organizer needs.
Cords,software for Windows XP and 7. They have Sharp OZ-730,OZ-770 and YO-520. They also repair ALL Sharp organizers with a keyboard.
www.thewizardshop.net
803-736-4382
Nov 29, 2010 | Sharp Wizard OZ-730
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
I have an OZ-730 sharp wizard and it will not turn on, batteries are new and i tried the reset button. last time i used it the screen went black and then it turned off? help
Be sure the batteries are in correctly and are good, be sure the battery switch is back to the "normal position" - also it may have to be reset to work again - here is the instruction manual for doing that , page 7 chapter 1:
http://www.promsoft.com/dev/oz700sdk/oz7xx_manual.pdf
Sep 17, 2009 | Sharp Wizard OZ-730
Sharp OZ-730 (deceased
When you held the start button down and pressed the reset, did you get a message appear ? as per the manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000002412.pdf
Oct 11, 2017 | Sharp Wizard OZ-730
Forgotton password for Sharp OZ-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Jan 04, 2008 | Sharp Wizard OZ-730
Sharp Wizard OZ-730
Hi, I has this same problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
Dec 25, 2007 | Sharp Wizard OZ-730
Sharp Wizard OZ-730 docking module
Found it here -
http://underwooddistributing.com/Sharp/sharpyooz.html
but it's $49.95! I have to keep looking around the house.
Dec 21, 2007 | Sharp Wizard OZ-730
Sharp wizard oz-730
Oct 10, 2007 | Sharp Wizard OZ-730
Sharp Wizard OZ-730 Logo
171 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
