Kenmore elite oasis he model # 110.27072600 power just wouldnt come on worked last night this morning it wouldnt turn on. outlet is fine.
  • nick_wardell Sep 06, 2010
    I used a hair dryer and nothing changed. how do I figure out which part to replace in the control panel? There are 2 "control panel" parts...a green circuit board directly under the buttons and a gray plastic housed part. there are also six 120v fuses.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue seems to be with the control panel that has gone bad and needs to be replaced however, before replacing the panel you can take a hair dryer and blow some air so that if there is any moisture it blows it off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 04, 2010
  • Rylee Smith
    Rylee Smith Sep 06, 2010
    I am talking about the circuit board, also before replacing it check the door switch as well. Please post back for more assistance.
Kemmore elite oasis model # 110.28042701 type 581washing machine not turning on.
Make sure it is receiving power. Having confirmed this what works and what does not. Resubmit your inquiry with specifics so help can be rendered.
Nov 23, 2015 | Kenmore Washing Machines
My kenmore elite oasis washing machine stopped mid wash there is no power at all. Model #110.28092700
first plug a lamp or something you know works into the outlet.if lamp does'nt work,check the breaker at breaker panel.If that is not tripped,it may be the onoff switch,or timer on machine.
Sep 27, 2014 | Kenmore Oasis HT High-Efficiency 4.6 cu....
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE3 Front Loading Automatic Washer
Pull the plug and test the plug with a nitelight or lamp. Now try the washer. If the lamp lit and the washer. It appears there are many problems with the controlls of these machines. There is a leamon law for appliences. Sorry I think this is a Vista model made by microsoft and the best bet is to force the mfg. to return your hard earned money because it is defective.
http://www.complaintsboard.com/complaints/sears-kenmore-elite-oasis-washer-machine-c44278.html
Aug 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite OASIS 27082 do not power up
The motherboard (controller) has died.
You will have to replace the motherboard.
This motherboard is the cause of the dreaded F1 error codes as well.
Look at some of the other posts here for F1 errors.
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washer will not turn on
I have the same problem. I used the unit 2 days ago and no problems- just bragged about the unit yesterday and now today it will not turn on and it is no longer under warranty. I also checked to see if power to plug and it is fine. Any suggestions?
Aug 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
