Question about Conairphone CID 244
I am looking for a manual for Conairphone model #CM200 in order to program the memory
I need manual for conair 10 memory speaker phone
http://www.manualslib.com/manual/224019/Conairphone-Cid200.html
if this isn't it, just Google "manual for (insert model number)"
Jan 21, 2015 | Conair Lands Phones
I have a cm200 base station and need to sync it with my cp 200 radios
hi Raymond, we're a Motorola /Vertex Dealer and have the software and cables to program everything to match. as long as they are all on the same frequency range (meaning the new Portables are not VHF and the base is UHF, if both are the same, we can take care of programming for you, $35 each unit programmed. shoot an email over to us metrocom2 @ yahoo (dot) com - jenny
www.metrocomdc.com
Mar 20, 2014 | Motorola Radio Communications
Require instructions to set the memory on conairphone PR6202WCS
l found these manuals for Conair phones, and one of them may, hopefully, help:
http://www.retrevo.com/samples/Conairphone-manuals.html
May 27, 2011 | Cell Phones
WHER CAN I GET A FREE DRIVER FOR MY MAGICVISION USB WEB CAM.MODEL DR-CM200
http://members.driverguide.com/driver/detail.php?driverid=81685&action=downloadstart
Jan 26, 2011 | Digital Research MagicVision DR-CM200...
How to replace different numbers in the memory. Conair 13 memory speakerphone.
1) Press "STORE"
2) Dial the number you wish to save in a memory location.
3) Press either the "Priority Memory" keys (M1, M2, M3) or a keypad
number (0 through 9) to save the dialed number in that location.
To dial a stored number, if it's a "Priority Memory" number, just
press the key (M1, M2, or M3). If it's a number stored in 0 through
9, press "MEMORY", then the desired number key.
Here's a link to a manual for a ConairPhone memory phone:
http://www.conairphone.com/IBs/feature_telephone/sw6404.pdf
Mar 19, 2009 | Conair Lands Phones
Need manual for Conair Corded phone Model SW3414wcs
You should be able to get another Manual from the Conair Website and Download in PDF Form.
Jan 04, 2009 | Conair TAD920 Corded Phone
ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Jul 12, 2007 | Conair SW324WCS Corded Phone
Storing numbers in memory
Call conairphone, they will tell you over the phone how to sotre numbers. You can find their number by doing an online search. If you have an old model phone follow these steps. You have to make sure your batteries are working. Leave phone in cradle - press and release store button - dial the number - press and release store button again - press the button you want your number stored.
May 07, 2007 | Conairphone CID 244
Address book disappeared
I could not find the exact manual for your phone, but this one looks close and has instructions for programming the memory: http://www.conairphone.com/IBs/caller_id/cid200.pdf It says: BASIC MEMORY PROGRAMMING The CID200 comes with 10-memory dialing. NOTE: Your local phone company restricts the time you can have the handset off the base (off-hook). YOU SHOULD PROGRAM THE CID200 MEMORY WITH THE LINE CORD UNPLUGGED FROM THE WALL, IF YOU ARE GOING TO PROGRAM MORE THAN ONE PHONE NUMBER. Press [STORE] to enter memory store. Press the keypad to enter the number that you want to program. Press [STORE]. The ?MEM? will be displayed on the right corner of LCD. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. Copy from the Caller ID to Telephone Memory Press [Up Arrow] or [Down Arrow] until the Caller ID memory location to be copied appears on the LCD. Press [STORE] twice to enter memory store. The ?MEM? will be displayed on the right corner. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. If no key is pressed within 20 seconds, the LCD will return to ?Answer-Ready? mode. Repeat the above steps to store a different number in the same speed dial location, or to store a new number in a different speed dial location. NOTES: ? Pressing [PAUSE] will place a 4-second PAUSE into the number. Which may be required for accessing special phone services. ? You can store a number with up to 16 digits maximum. Only the last 14 digits will be displayed.
Mar 15, 2007 | Conairphone CID 244
Conairphone CID 244 Logo
192 people viewed this question
Top Conair Lands Phones Experts
k24674
Tom Chichester
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
