Question about Hayward Pool & Spa
I have ahayward H1001D1 above ground pool heater running on nat gas has worked for 3 seasons with no problems last week heater started to make banging sound as if it was rapid cycling ichanged filter and checked water flow across heater it seems fine heater is still making banging noise please give trouble shooting help i am a electrical contractor thank you
  • 990 Answers
If your external by-pass is closed almost all the way then it will be your internal by-pass. You find this assembly inside the water manifold at the side of the heater. Part should be about 70-80 bucks.
It is suppose to regulate the water flow so it has time to heat but not boil. Yours is probally missing the control disc and letting all the water flow past the heater so the water in the heater is boiling and that is the banging you hear. Good luck.
Posted on Sep 04, 2010
Error message Fault. High Limit , upon attempting to use the heater for the first time this season
either not enough water flowing through heater or low gas pressure to overheat unit replace high limit in stack if not one replace one on bottom white unit with 2 white wires
May 26, 2016 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
RayPac Pool heater won't light
check gas pressure too low it overheated replace fusible link on bottom after gas is fixed then clean heat exchange of soot
Apr 20, 2012 | Raypak 130,000 BTU Natural Gas Pool...
Hayward above ground pool heater, gas, worked great last year, but this year can not get to turn on at all, and yes the gas is turned on, could it be something to check with a volt meter?
pressure switch is a common problem on this model. remove top and its located on top of water inlet header.set meter to "continuity" setting .remove 2 wires to switch and test WITH pump running.as you probably know,unit will not operate unless front door panel is in place.
Sep 02, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Green light not working on Intex Saltwater System, model #8110
It is easier to explain than to type it all out you can call me at 586-625-2300
we have never had any issues with water clarity
in general I will say you are not filtering enough in normal mode
Mark
Jul 08, 2009 | Intex Automatic Salt Water System for ...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Leaks after a couple of weeks use
You may need to put a hartford loop in your plumbing between your chlorinator and the heater. The chloriene will back up in the line bad when the pump is off and corrode the exchanger. A hartford loop is simpley a loop than runs low then high above the top of the heater so it can trap gasses in the line and won't let them get back in the line. If all else fails you can use a floater. Be sure to check your PH also. Good luck.
May 30, 2009 | Hayward H Series Electronic Ignition...
Hayward pool heater wont stay lit
Follow the troubleshooting guide on page 36 of this owners manual. It will walk you through problem solving... http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
May 25, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Pool & Spa Logo
312 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
