Question about Dell Precision M60 Notebook
LCD Screen Problem on booting
Thh lcd screen displays in red, then green, and change into other colors. No image is displayed. I have connected to another monitor but it does not display anything. Is the video card damaged? How can it be replaced?
  • lmarqs Jun 15, 2008
    My m60 has started showing a strange problem. On cold reboot from powered off the system shows the bios boot up display and the windows xp startup logo as normal. However as soon as the os loads the full display driver (i.e. just before the xp login screen appears) the display goes blank. This is not a blue screen or a white screen but it looks like all power has been removed from the lcd matrix and what you can see is the back reflective surface illuminated by the back light but viewed through a totally transparent lcd matrix. The system meanwhile appears to continue to boot up normally. If I then power off the laptop by holding down the power button and and then reboot and use F8 to select boot up in VGA mode the system boots up normally (but into VGA mode display). If at the XP login screen I tell the system to reboot and let it come up normally it boots up perfectly into full high resolution video mode!
  • 37 Answers
Ok, when connecting to another monitor, be sure to use the Function Key, and press the appropriate F Key to enable an external monitor. Without doing this, you will never see an external picture.
If that picture is fine, then yes, you need to think about your video card, and I would start with updating the driver.
Posted on May 16, 2008
No image, Just red and blue vertical line on display.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
What your describing is a major video problem, poor color and it is blurr, It would be far cheaper to replace the monitor with a new one.
Mar 08, 2012 | Samsung SyncMaster Computers & Internet
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My viewsonic vx2025wm 20.1 lcdmonitorgoes green,sometimesyellow,then returns towhite screen
check your cable connection if the color changes.. as normally bad or lose display connection will cause this problem..
but if it turn to total white without any image.. then most probably the LCD monitor is faulty..
but there are some cases when your display card that is giving this funny problem.. if it get too hot.. check your PC display card whether the cooling fan is turning or jam.. this is the main cause the display card get overheat and give you funny display...
May 23, 2010 | HP Computers & Internet
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Video card
from the central unity.
Mar 05, 2008 | Dell Precision M60 Notebook
Dell Precision M60 Notebook Logo
173 people viewed this question
Alun Cox
