Question about Emerson Televison & Video
All of a sudden, the majority of the TV stations we could get are now overridden with the message "Protected Program by TV-PG". Help!!!
  • dlwillauer Sep 04, 2010
    Thanks for the suggestion. Unfortunately our TV is so old (at least 10 years), we have no idea where the manual is.
    Your comment helped tremendously. I was able to figure it out. Thanks so much.
    Novelist:
  • 132 Answers
Somehow your parental lock got turned on. You will have to see if you can find it in the menu and turn it off. You should be able to find the instructions in the owner's manual as to how to do this if you can't figure it out. It will probably ask you for your password. If you do not know your password, the owner's manual will tell you how to reset it. What is the model number of the tv?
Posted on Sep 04, 2010
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
MESSAGE THAT PROTECTED PROGRAM TV-PG HOW DO I FIX THIS
You can't. There's a chip inside that prevents a copyrighted program form being recorded.
Oct 30, 2013 | RCA (DTA800B1) Video Converter
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
Nov 24, 2012 | Hardware & Accessories
AFTER TURNNING TV ON 2HOURS (+OR-) THE SCREEN GOES BLACK ON CABLE STATIONS AND THE FOLLOWING APPEARS ON SCREEN ------- PROTECTED PROGRAM BY TV-PG ------ WHAT STEPS MUST I TAKE TO CORRECT THIS ON MY TV ! ...
The parental control or V chip settings are turn ON. I would suggest to find it in the menu and turn it OFF.
What is the model number of your TV?
Dec 20, 2010 | Televison & Video
The wording "protected program by TV PG" is on my tv and i cannot access any of my tv channels. How do I remove the block?
Access the menu and go to Parental Control. Change the settings to allow the types of programs you want to be unprotected.
Jul 09, 2009 | Televison & Video
Locked out of tv
Maybe Try Unplugging It? Some T.v's Also Have A Reset On Them. If That Doesn't Help Please List The Specific Make And Model.
Jan 05, 2009 | Zenith H25F36DT 25" TV
WILL NOT ALLOW ME TO WATCH ANY CHANNELS
If you are on a protected channel where you are getting the "Protected Program by TV-etc" you have to get out of that channel and go to a channel that is not protected. That will allow you to hit your "Menu" button and access the V-Chip settings on your TV. Depending on the type of TV you have, you may end up using your Vol Up button as a sort of "Enter" button. Hope that helps!
May 12, 2008 | Symphonic ST420FF 20" TV
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Message protected program by tv-pg
Go into Menu /V Chip arrow key up to tv rating should show all locked volume down or visversa should should view all Note may have to volume up to get to options from menu depending on how old the tv is.
Apr 04, 2007 | Emerson EWV403 VHS VCR
Televison & Video Logo
208 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
