I have a Kenmore Heavy Duty 70 series washer older model. It will not alow cold water to fill washer. Tried warm and hot water only fills the tank. Hot water will fill fine with no problem.
  • Washing Mach... Master
  • 2,180 Answers
Shut the house water valve off,take off the cold water line on the back of the washer and stick it in the tub of the washer,have someone hold the hose and turn on the cold water valve,if water comes out then you need to change out the water valve on the washer,if no water comes out then you have a problem with the house water valve.there are screens in the valves see if you canpop out the screen and clean it out and put it back into the valve,you can try that but sediment could have went through the screen and damaged the valve,if so change it out.next time send the model number and i can give you part numbers,let me know what you find
Posted on Sep 04, 2010
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
GE super capacity heavy duty washing not filling w/hot water
On an older model washer, you probably have a bad water valve. (hot water solenoid coil electrically " open ") Newer models, now there's a can of worms. Some models use thermistatically controled water valves to limit water temps, so you may not be able to get true hot water. Also, if you are checking the temp as the machine fills, some models will only fill with cold if the lid is open. (safety feature) The only way to see what is really going on is to fill the machine with cold and use a thermometer to check the water temp, then, pump that out and fill (with the lid closed) with hot and check to see if that temp is higher. As stated previously, water temp may not really be " HOT " but may be warmer than " COLD ". That may be as good as you will be able to do, as all manufacturers are trying to reduce energy consumption. Thank your government.
Jan 21, 2010 | Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Dec 14, 2008 | Kenmore 24622 Top Load Washer
The screens are filled with minerals which cause the washer to fill very slowly, need to know how to get at the screens so I can clean them. Kenmore Heavy Duty 70 Series washer.
HI thanks for your question.remove the hot& cold hoses. inside the valve you will see screens. scrape with a small screwdriver. replace hoses & try. if it works, great if not replace water valve. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Washing Machines
Kenmore washer machine heavy duty 70 series
most likely a water pressure issue try adj shut off valve off slowly until noise stops if water flow not enough ckd fill screens in back of valve for sediment and trash
Apr 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
