Question about Dometic Refrigerators
I have a Dometic RM 2604 freezer is at 10 degrees and frig is warm
  • 51 Answers
SOURCE: Dometic RM 2804, freezer is
Adjust your temp control on the fins inside the fridge move it down it just slides on the fin. You may need a fan on the back of the coil to increase the air flow depending on the heat outside
Posted on Sep 08, 2008
docjohn174
  • 943 Answers
SOURCE: frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Posted on Oct 17, 2008
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Posted on Aug 24, 2009
woodchuck789
  • 4066 Answers
SOURCE: I have a Dometic New Dimensions side by side frig
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Sep 30, 2009
SOURCE: Three year old Dometic RM
My rm2555 has just failed on 240 volt. But not 12 volt.
It turned out to be the 240 volt element .
Fairly easy to replace. If you have a multimeter test the resistance, mine was open circuit.
Does yours work on 12volt?
The two heater elements (ie 12v and 240v ) are on the right when viewed from behind with four large wires coming out, plus an earth wire. There are labels on some of the wires. The 12 volt conects into a terminal connector, where as the 240 volt is fitted with spade connectors and is attached to the printed circuit board, under the white plastic cover. The elements are "L" shaped and are just pushed down in down next to each other. The cover seems to unclip fairly easily to enable removal.
Hope this helps.
Mark
Posted on Jan 08, 2011
My Dometic freezer is 15 degrees and the frig isnt cooling Why
Might be a defrosting problem or the evaporated fan motor isn't working
Apr 02, 2017 | Dometic Refrigerators
Waht makes a Dometic 1402 work normal on electric but the refridgerator warms up when on gas? Freezer warms up slightly but refridgerator 10 to 15 degrees?
Dometic had several recalls for that problem, faulty thermostat I believe. Mine does the same thing, but I haven't taken it out to replace the thermostat / thermocoupler.
Aug 20, 2014 | Dometic Refrigerators
Dometic 3 way fridge RM 2604
in back remove cover see heater line from board two black wires going to flu pipe remove and replace
Oct 21, 2012 | Dometic Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Hi,have a dometic rvfridge ,gas and e,ec,was
I would recomend that you downlaod the diagnostic sevice manual, and test a few things yourself.
Roy
Jul 29, 2010 | Dometic RM2652 Refrigerator
Model RM 2604, cannot get it to run. The person I bought the trailer could not either. I just bought the thing, so I am still learning about it.
dometic refrigerators work on an closed circuit absorbtion system
to work it must be level and, must have either a flame or, an electric heating element to make it cool
Sep 05, 2009 | Refrigerators
Frig does not go below 52 degrees.. Freezer OK
MAY HAVE PUNCHED HOLE IN EVAPORATOR AND GAS LOW????
Jun 18, 2009 | Dometic NDR 1292 Refrigerator
Frig and freezer warm most of the time
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
Dometic RM 2804, freezer is ice cold, fridge is 60 degrees to warm for food
Aug 22, 2008 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
